![]() | Home > Maintenance & Modifications > Refurbishing the rear cross member |
| MarcusM Member Since: 29 Jan 2020 Location: Nottingham Posts: 101
Hey CRT188- I have just done mine using the Buzzweld kit. Used a wire bush on a drill to clean it back to the metal and take all surface corrosion off. Products worked really well just make sure you mask off well.
Click image to enlarge Click image to enlarge Keswick green 2007 Defender 90 TD5 |
| CRT188 Member Since: 28 Mar 2016 Location: surrey Posts: 10
Hi Marcus
Looks great!! I’m crap at this kind of stuff, what type of brush did you use? First time I’m actually trying to do anything on the truck myself |
| sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145
You'll be fine, I'm very new to all this and I did mine a couple of days ago. I just sanded mine by hand with some 80grit sand paper and then sprayed it with the buzzweld 2 part crossmember kit. As previously said, just double check you have masked everything you don't want spraying
Click image to enlarge Click image to enlarge Last edited by sgreenham on 13th Apr 2020 8:07pm. Edited 1 time in total |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Nice tidy work
2008 SVX 90 2000 XS TD5 90 |
CRT Just used the Buzzweld kit - comes with the rust encapsulator spray can and then the black spray. I’m pretty new to it to - was the first big job I did- pretty easy and gives a great result! Good luck with it and post some pics Keswick green 2007 Defender 90 TD5
Thanks guys, I’ll order it tomorrow, not sure if they are open.
This is the one I used - they are still shipping out - I imagine they are doing well right now!
https://www.buzzweld.co.uk/fxliner-1k-cros...g-kit.html Keswick green 2007 Defender 90 TD5 |
| All times are GMT |
