![]() | Home > Maintenance & Modifications > Optimil Puddle light wiring diagram. |
| derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 568
Been abit of a wally and misplaced the wiring instructions for the optimil puddle lamps connection to the AS10 ecu.
Does anyone have a copy they could take a picture of and send it me? Much appreciated Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
I messaged Optimil them selves didn’t think I’d get a reply being late on Good Friday, but they sent it me.
Here we go for future reference :- Click image to enlarge 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Excellent service
2008 SVX 90 2000 XS TD5 90 |
I wired them to near the AS10, I have a Td5 and the plugs are there behind the drivers side speaker. 👍
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
This means the wing mirror lights will come on whenever the interior light is on. Not desirable for some. Wiring to the 10AS unit means they only come on/off with the lock/unlock 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285
Maybe I should have explained better, the two wires (purple/brown & purple white) from the AS10 go to the interior light to switch it on when you unlock/open the doors, it works exactly the same. They do not come on if you switch the light on only when you open the door or unlock with the remote. 2008 Defender 110 XS CSW
Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
| silvermilnec Member Since: 23 Nov 2021 Location: West Yorkshire Posts: 27
Sorry to bring up an old thread!
I’m doing the same but I don’t have factory alarm unit. Can I just tap into the interior light, cable running up the side pillow? Cheers guys |
Yes you can, but even with no central locking or immobilizer I'm led to believe there is still an AS10 ecu, unless yours is a pre Td5.
I stand to be corrected! Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
| All times are GMT |
