Home > Maintenance & Modifications > Bilstein woes
stephan123
Bilstein woes
Hi,
Swapped out my original shocks for the much-heralded Bilstein B6s a few months ago but find the ride far too hard. Finally decided to change to a slightly softer setup but want to keep original springs. Any sugestions? Many thanks
Post #824646 11th Apr 2020 8:00pm
Sulisuli
I have the fox springs and I find them really good, I have a hardtop so the suspension was always harsh unless towing Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #824649 11th Apr 2020 8:03pm
stephan123
Thanks Simon, I've heard good thinkg about the Fox springs. Any chance you could send me a link for the correct types? On a side note how easy is it to change the shocks? Got them done by my local mechanic last time but given the current shudown I was hoping to have a crack at doing it myself. Aside from lack of self-confidence i don't have a jack Embarassed
Post #824654 11th Apr 2020 8:16pm
jst
You dont need a jack to change shocks. Granted easier with as you can take wheel off but you dont have to. Is there not a jack with the vehicle? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #824676 11th Apr 2020 9:23pm
stephan123
No jack unfortunately. My truck is a later model and my guess is they stopped supplying tools/jack. Happily surprised to hear that shocks can he removed/fitted at ground level. Any potential pitfalls i should be aware off? or is it just a case a removing bolts and replacing old with new?
Post #824680 11th Apr 2020 9:52pm
Sulisuli
I purchased mine from alive tuning Thumbs Up have to admit I didn’t change them I just assisted forum member roy5695 Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #824685 11th Apr 2020 10:29pm
Roy5695
Should be a jack under the passenger seat.
The rears are easy enough to change. Just 2 nuts.
The fronts are a bit more complex but can still be done without a Jack. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #824688 11th Apr 2020 10:50pm
Co1
When you do the fronts it is a bit of a pain in the arise but doable. I wish I had swapped the turret and turret bolts for half when I did mine, so if your pockets are deep enough I’d recommend this.
Post #824712 12th Apr 2020 7:11am
