![]() | Home > Maintenance & Modifications > Nakatanenga Aerial |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I have the naka ariel and it great
Are you using std headunit? Or double din? 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Reason I ask is mosjority if upgraded units have the option to power the antenna which won’t work with the naka anyway
But for am/fm I found out the long way that yes the am/fm does work with out power but dab does not if powered through headunit Why dont you want to power it? Hope this helps 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
Hi Paul no just have a shallow single din it just for am/fm reception I’ve had dab too patchy for me cheers chris
My dab was rubbish till I got the naka ariel been all over the uk and had no problems with Dan now 2008 110 2.4 XS Utility (Hagrid)
DAB not dan
If you just want good and/fm a decent flexi Ariel would do you tbh the naka ones not cheap but defo worth it if you want dab 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Thanks Paul 👍
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20946 ![]() ![]() |
I’ve tested mine and it seems good, but still not in full use yet until I’ve done my install.
Don’t forget also if you have a HU that can power a DAB aerial to have that setting turned OFF with the Aerial externally wired in otherwise it won’t work. On mine this come up on the opening screen after power has been disconnected. From when I tried the aerial it picked up a good amount of DAB channels and that was parked in a relatively confined area amongst buildings too so I’d say that’s pretty good. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I can't answer the original question (about FM/AM reception without power) although I would expect the aerial to work in this scenario, but I can say that I have been massively impressed with the performance of mine.
When I first fitted a DAB receiver I had a DAB aerial mag-mounted to a steel plate on the roof-rack (the steel plate providing a ground plane) and the reception was utterly useless. It would work fine very locally, but was completely inadequate for regualr use. The Nak aerial provides stunning reception even in areas where I wouldn't expect any reception. It made a nice change to be more impressed than I expected to be rather than less impressed. |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
I am using the Naka aerial for AM/FM only, without power (in hilly Cumbria). It's noticeably better than the factory aerial was. On the school run, my wife's Disco loses signal at several points, but in the Landy the Naka aerial gives me uninterrupted reception.
Proof that the Landy is better than a modern vehicle and more reliable. ![]() |
Factory aerial was terrible I found, barely find an FM station or two and would lose signal. ____\We|Will|Win/___
