Home > Maintenance & Modifications > Air con blower fan not working
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
With all this self isolation stuff I thought I might as well sort out the air conditioning on my TD5. When you turn it on it does nothing. Well except for the engine sound changing so that rules out the pump clutch at least. Any suggestions for things to look at? And if its important its a below dash type. No idea who makes it as it does not look like the standard land rover one.
Would also like to replace the missing vent and temperature dial so if someone can identify the brand that'd be much appreciated. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #824161 8th Apr 2020 6:19pm
montyjn
Charcoal,
I'd check the fan resistor block? Are you missing all 3 speeds? If not, fuse?
Monty
Post #824268 9th Apr 2020 12:50pm
dorsetsmith
fuse 9 30 amp passer fuse box
Post #824282 9th Apr 2020 2:52pm
charcoal
Thanks guys, yes all 3 speeds missing. Where is the resistor block for the fan? Dorset would this fuse be in the standard fuse box behind the gear stick? None look like they are for AC. 1999 Land Rover Defender 110 td5 station wagon
Post #824306 9th Apr 2020 4:27pm
dorsetsmith
C0068
Post #824330 9th Apr 2020 6:39pm
charcoal
Great thanks, had checked the fuse and it was fine, will take it out and check the rest tomorrow. 1999 Land Rover Defender 110 td5 station wagon
Post #824334 9th Apr 2020 7:32pm
montyjn
Resistor block on mine is on the passenger side of the engine bay in front of the heater box. I suspect if you have not speeds at all it is unlikely to be this, but worth checking. My AC is the in-dash type from the 80s, so the setup may be different.
Post #824805 12th Apr 2020 2:18pm
Mo Murphy
Is that an aftermarket set up ?
50 Shades of Pennine Grey
Post #824814 12th Apr 2020 3:04pm
charcoal
Thanks Monty had a look in the engine bar but there is nothing there so it must be with the blower. Im not entirely sure Mo, Id think so as its not the genuine bar but its unbranded and I cannot find any ones that look the same. 1999 Land Rover Defender 110 td5 station wagon
Post #824852 12th Apr 2020 5:44pm
montyjn
Mo, nope - it was a factory fit option from 1988. I think it is the same as you see in export cars / NAS spec. Has a harrison compressor and a different dash plate which replaces the shelf. I can send some pics if of interest. I had it rebuilt last year so it all functions - rather helpful with the V8 in the heat.
Charcoal, I'll try and take some pictures today for you. One other thing I found on mine (while the aforementioned rebuild was going on) was an inline fuse hidden in the dash..
Post #824934 13th Apr 2020 9:44am
Mo Murphy
Thanks monty, your in dash type set up looks much more effective than the TD5 knee cooler.
Charcoals set up isn't the same as the TD5 as it doesn't extend to the ends of the under dash which leads me to think that it is an aftermarket fitment.
Post #824937 13th Apr 2020 10:01am
charcoal
Thanks Monty, took it out the footwell today to have a look and couldn't find anything that resembled a resistor. It also seemed to be getting volts to the motor so maybe thats busted? To be honest thinking I might just get rid of it and use the pump as an air compressor or something. Yes Mo its not even a standard Land Rover one. Had a look all over it for any sort of branding and the only thing I found was a sticker with what looked like a serial number and a part number, the latter being EV15120 but couldn't find anything about it online. It is definitely for a Defender though as it fits too perfectly to be a generic model. 1999 Land Rover Defender 110 td5 station wagon
Post #825046 13th Apr 2020 7:08pm
montyjn
Mo,
Pictures of my system below I keep meaning to write a review of the job Fenair did restoring it (especially given all the time we have at the moment with the lock down). These pictures are pre-restoration.
Charcoal - apoloiges, will send the resistor picture today. I believe your system was an aftermarket one which there are details around for (I think it is still for sale somewhere).
Post #825128 14th Apr 2020 8:30am
montyjn
Charcoal,
Is this your system:
https://www.elitekl.co.uk/land-rover-defen...ning-kits/
A google search for underdash aircon brings up quite a few similar systems and a fair few forum posts related to they system as a whole.
Here is a picture of the location of the resistor on mine (passenger side on a RHD vehicle):
What the inside looks like:
Hope that helps.
ATB
Monty
Post #825134 14th Apr 2020 8:39am
Mo Murphy
Thanks for the pics monty, it does look a better system than the Underdash units.
Post #825155 14th Apr 2020 10:13am
