![]() | Home > Wheels & Tyres > Larger tyre size on a standard 90 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8244 ![]() ![]() ![]() |
255.85r 16 with a little rubbing on articulation. (33")
235.85r16 or 265.75r16 would be standard fitment size, these sizes work well for 99% of time and use. (31") Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Many thanks James, I appreciate your help.
Regards Mick |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
If you're only doing 2000 miles a year why wouldn't you just leave them?
I used to change wheels around two or three times a year but eventually it just becomes a faff and you give up! --- 2006 Defender 110 SW 300Tdi β’ 2011 Ford Ranger XLT crewcab β’ 2015 Defender 110 Station Wagon Utility TDCi |
London 52 Member Since: 21 Oct 2014 Location: Lincoln Posts: 312 ![]() ![]() ![]() |
Hi Mick,
235/85/16s on Freestyles ![]() Don |
Hi Don,
Thanks for that. They seem to suit the truck well. The freestyles I have now look ok on the truck but the front caps wont fit. Do I have a different wheel or do you have spacers or magical centre caps? Thanks again. Mick |
Hi Mick,
I had the same problem so fitted 30mm Hubcentric Spacers ![]() Don |
Couple more photos Mick to give you an idea what they look like with spacers
![]() ![]() Click image to enlarge ![]() Click image to enlarge Don |
Hi Don,
Thanks again pal, I appreciate your time replying. I have heard mixed reviews on spacers. Some say don't do it as it puts the offset in a manor that increases strain so buy wheels with correct offset, but I thought that would put the same strain on the same parts - but then I am new to this so I welcome the feedback from people. Also, how do you go on with insurance with spacers? ATB Mick |
Hi Mick,
I always update my insurance company with any changes from standard spec. I've recently just had a Alive Stage 1 Remap which i declared with no increase in premium at the moment plus the change in wheels with spacers were also declared. To be honest, it's just not worth taking a chance if the worst did happened! Don |
c_eilersen Member Since: 09 Oct 2016 Location: Copenhagen Posts: 11 ![]() ![]() ![]() |
255/85 without rubbing - 285/75 with minor rubbing, which you can prevent with the steering/turning radius adjustment bolts.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20788 ![]() ![]() |
I run 255βs with no spacers and lock stops adjusted as mentioned above.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Done over 100k with spacers fitted and not replaced any wheel bearings
Just saying ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17739 ![]() ![]() ![]() |
The effect of wheel spacers on hub bearing loads CANNOT be any different to the effect of running wheels with the same resultant offset, so the myth that they do is just that, a myth, uninformed piffle which has gained credence as a result of the Internet.
The effects of spacers, different offset wheels, or tyre size changes on hub bearing loads will depend on many factors but unless you go to absurd extremes is likely to be negligible. For example 30mm spacers will load your bearings less than a fat passenger. I have long maintained that good-quality, properly-designed spacers fitted correctly are entirely safe. I think that the reason that spacers generically seem to have a bad reputation is a result of the hooky antics of the 'slammed and rimmed' boy racer brigade. it's one of those things where inevitably someone's neighbour's cousin's friend knows someone whose spacers failed, but nobody actually knows of a genuine failure. ![]() |
From what I've read spacer failure has been caused by lack of basic mantence I.e. Not checking that they are secured properly - no different to the wheel nuts.
It's only the fact there is twice the chance of this being an issue that causes it. (Should these people even be driving which such poor maintence levels? ![]() I personally prefer not to use them, but each to their own. ![]() β½οΈπ’οΈβοΈπ§°πͺ Last edited by custom90 on 9th Apr 2020 12:36pm. Edited 1 time in total |
