![]() | Home > Puma (Tdci) > Headlights not working... |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
have you checked the relay under the dash access panel that feeds the underseat one? Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 238 ![]() ![]() ![]() |
Hi D-R,
I supose The under seat relay will not click when the under dash is not working.. So it must be in between the under seat relay and headlights. |
![]() Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 ![]() ![]() |
[quote="TopQ1967"]Hi D-R,
I supose The under seat relay will not click when the under dash is not working.. So it must be in between the under seat relay and headlights.[/quote] May be, the light switch to replace? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1863 ![]() ![]() ![]() |
I wasn't aware the headlight circuit had a relay - hence the common fault of a burnt out column switch and the aftermarket headlight looms with relays that take the load off the column switch - unless LR in their wisdom fitted relays to the last few years of production.....?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
There has always been one relay, which ensure that the headlights are extinguished if you turn off the ignition, however it doesn't prevent the entire headlamp current being passed by both the light-switch and the dip-switch, hence the common failures of both/either switch.
I believe that very late models may have improved wiring, but I have never come across one. |
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
Jops, the wiring was changed with MY12 to use a relay, which prevents the switch from too much current.
TheGrumpy Member Since: 15 Oct 2015 Location: Wynnum Posts: 8 ![]() ![]() |
Hi Quirin, did you get a fix for the lights?
I’ve got a MY16 starting to play up the same way! |
