Home > Technical > Gear lever movement? |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 185 |
Hi Chris,
I had an intermittent small vibration noise from my gear lever. I don't remember any weight movement or noise after I removed the lever. I just glued it as described. Gearstick vibration noise was caused by engine vibration. This cured my problem anyway. It was an easy job, just left the stick off overnight for superglue to dry properly. Not sure if this helps but thought I'd share. Cheers Chris |
10th Mar 2020 1:57pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 445 |
Hi Chris
Cheers. Looks like I will have to take it off again and apply some glue and go through the pain of getting the gaiter back on! Cheers, much appreciated. |
10th Mar 2020 6:10pm |
No worries.
As a side note. I didn’t have any problem with the gaiter. Just lifted it up over the top of the stick and when putting back, going underneath from bottom through gaiter. Not sure if that’s what you did. Probably stating the obvious. Anyway best of luck Sir. Cheers Chris |
10th Mar 2020 6:51pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
It is entirely possible to push the gaiter down below the gear lever attachment, then ease it back up afterwards, which saves disturbing the mats/carpet and freeing it from the transfer lever.
In the course of developing my "heritage knob" I have done this many times of late! |
10th Mar 2020 6:58pm |
Cheers.
Black wolf, that’s what I tried to do, but either I am useless or my technique was very poor! Either way the pain was unreal. Hence I resorted to lifting the matting and going up underneath I will save the job for when I have some patience in the bank! Cheers all. |
10th Mar 2020 7:04pm |
Part of the problem is I don’t really know what noise I am listening for! I definitely have a rattle from that area or somewhere close, but I just cannot track it.
As I have learned, trial and error works in the end! |
10th Mar 2020 7:19pm |
RILEY Member Since: 01 Feb 2013 Location: United Kingdom Posts: 35 |
I agree with you, that gaiter around ....Is an absolute Ars0le !!!!
placed it in hot water piece of cake its just seasoned ,needs tweaking one life, sell it |
3rd Apr 2020 7:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19531 |
Do you mean movement whilst stationary or on the move?
There is general engine movement at idle in neutral, (vibration mainly,) if it's on the move and you've noticed a recent difference then I'd get your Propshaft UJ's checked as I found that this was when I had a problem with a UJ. Usually more pronounced at slower speeds. Another scenario is that the Nylon ball joint is cracked or degraded, I also had this and couldn't see it was broken until removed for greasing. I now have the Shift-R V2 instead from TMD which do far has been brilliant and nicely greased too. This is at about 74k miles or so. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
3rd Apr 2020 8:02pm |
Think he's struggling with the arseh0le gator tbh /plus possible other issues
bit of rubber water hose around the lever ,cures all Ah back to the series days one life, sell it |
3rd Apr 2020 8:13pm |
Hi, when stationary there is a very slight movement or lift vertically, maybe only a few mm or so. I think I need to looking the Shift-R! Cheers. |
4th Apr 2020 3:52pm |
