Light fittings water ingress and Checktemp | |
Two questions, may as well create one thread instead of two.
Can anybody confirm the electrical supply for Checktemp units?
I imagine it is Ignition Switched live and ground only, not an additional permanent live or interior lighting Trigger as well?
The other wiring for sensors is not a concern, I'm asking because I don't have one of these units yet and I'm thinking sat putting wiring in therefore ready for use down the line.
Second issue.
For some reason I have found moisture in my LUX LED reverse light and also wet in the Wipac SMD number plate light.
The latter quite a lot.
I did use a hair dryer carefully before, but after time it's condensed again. These units are supposed to be fully sealed but I suppose with "strong water jets" it still doesn't cut the mustard.
I have some Silica gel packets in a plastic zip lock bag thing, I'm wondering if that may do it what do you think?
Or the other option is to replace.
Any thoughts or info appreciated, I don't doubt many have been here before. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____
_//*β½οΈπ’οΈβοΈπ§°*\\_
3rd Apr 2020 5:56pm |
