![]() | Home > Td5 > What else should I do when the dash is off a 2004 TD5?? |
Mumpa Member Since: 23 Nov 2019 Location: Alberta Posts: 12 ![]() ![]() ![]() |
When things get a bit warmer here in snowy Alberta, I'll be fitting the additional windscreen washer jet.
While the dash is off, well some of it anyway, is there anything else I should be doing? Any particular areas I should be paying attention to? Thank you in advance ![]() |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
Agree ....And to add only use Genuine LR Spindles
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
Yes
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964 ![]() ![]() |
Dynamat
Wire in about a million USB sockets, especially is you've got a wife and kids
![]() But shout it at them in German because life is also terrifying and confusing... |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673 ![]() ![]() ![]() |
Buy a second screen washer and position them either side of the original, blank off the centre hole.
Add a T piece to the original washer pipe and run new pipe to the back of the relocated washers. Cheap and cheerful and much better than the original single original. Have fun |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
The wiper park switch on the motor is made out of cream cheese - so I'd change that whilst you're in there. JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
