Home > Puma (Tdci) > Coolant leak
Martin 911-87
Sweden
Coolant leak
Hi
I had a small and difficult to find coolant leak in the front of my car.
After some troubleshooting I found out that one of the coolant hoses from the after market Webasto heater was leaking.
Both hoses were routed form the heater (installed in lwr fwd front section of the car) up behind the water pump and up to the "heater control module".
One of the hoses had rubbed against a clamp just behind the water pump, creating a small hole.
Could be worth checking if you have a after market heater installed and experience a small coolant leak.
/Martin
Post #822750 1st Apr 2020 4:30pm
