Home > In Car Electronics > Labcraft Map Light
ak615
Labcraft Map Light
I've been meaning to fit a map light for a while now but wasn't sure where to mount it. Thanks to jem90's post on the osram map light the solution was found.
I opted for the labcraft version mainly because of the red light option ( ooer missus).
I found one reasonably priced on eBay £24.95 https://www.ebay.co.uk/itm/201486223886
first up removed the side vent and dash screws (later realised that removal of the lower speaker would allow me to reach right up)
drilled and tapped two hole for m5 bolts self tappers would probably have done
I then fitted nuts to the bolts a belt and braces job, also drilled 6mm hole for wires
cable ran to piggy back 2A fuse on AC circuit
I fitted a 10mm tool clip using the existing screw on the washer pipe cover
I'm pleased with the light and thanks again to jem90 for the inspiration
Post #822031 29th Mar 2020 12:57pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Nicely installed and a nice bit of kit. I particularly like the ability to switch to red light which (unless you suffer from red/green colour blindness) is more efficient than white light for night vision.
Post #822038 29th Mar 2020 1:12pm
gcc130
Very neat👍
Post #822042 29th Mar 2020 1:55pm
bugsaint
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Great idea to locate it on the pillar and the clip! Thumbs Up
Post #822046 29th Mar 2020 2:07pm
Jem_90
United Kingdom 2011 Defender 110 Puma 2.4 USW Baltic Blue
Thumbs Up That looks Great !!!
This community gives me so many ideas and inspiration. Cool
Red led's that's a nice touch, won't spoil your night vision.
Post #822286 30th Mar 2020 4:35pm
Zed
Very tidy. Nice work. WARNING.
Post #822289 30th Mar 2020 4:47pm
