Home > Maintenance & Modifications > Drivers Seat Fuse Box - Switched live
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I've added an additional fusebox to run an amp/charging points etc. I want it to be on a switched live so that when the ignition is off nothing runs the battery down.
Can anyone recommend the best way to wire the live in. I want it to be a chunky feed so I'm not restricted by what I can connect to the additional fuse box in the future.
I don't really want to have to open up the bottom of the original fuse box and also not do a Frankenstein by just using an O ring on one of the fuse screws.
Thanks
Post #806050 13th Dec 2019 10:47am
rallysteve
What year of vehicle have you got and does it have a heated windscreen fitted?
A TD5 without heated screen has a suitable live terminal and fuse position in the underseat fusebox which you can use. There is no spare ignition live though. You should be able to pick up an ignition live (white with green stripe) from the ECU connections though and use this to switch an additional relay.
84' 90 3.9 V8 Caged Pickup Build Thread
Mobile Diesel Heater Build Thread
Post #806060 13th Dec 2019 1:11pm
boxoftricks
Hi, Its a 2.4 TDCI 110
Post #806078 13th Dec 2019 4:54pm
PaulMc
You can take the permanent live for your relay, from C0575 using an M5 eyelet -
You take the ignition-switched live to trigger the relay, from the speed transducer C0195 pin 1 -
C0195 is a 3-way female Econoseal connector - you can tap-off the ignition-switched live, using an inline male to female link, with a wire piggy-backed off of pin 1, to the relay in the fuse box compartment.
Something like this -
. Paul.
Post #806089 13th Dec 2019 6:41pm
boxoftricks
Perfect thanks mate..... just ordered a relay
Post #806091 13th Dec 2019 6:53pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Paul, did you draw the wiring diagram? if so, what software did you use? Looks very pro.
Post #806196 14th Dec 2019 5:37pm
PaulMc
The connector faces are .jpg files - screen-grabbed from the RAVE and TOPIX pages.
I've then rotated or flipped them and swapped around the cavity numbers to suit.
I've then put them into a PowerPoint slide, sized and positioned them, and drawn the coloured lines representing the cables to connect them.
The relay was made entirely of PowerPoint drawing objects. Paul.
Post #806202 14th Dec 2019 5:53pm
macfrank
ah, „hand made“ then Smile I hoped there was a software to draw more complex diagrams.
Post #806258 15th Dec 2019 8:05am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Might be easier to take permanent live direct from battery to the relay and then switched live from the cigar lighter.
Depending on where you plan to have the aux fusebox of course.
Post #806419 16th Dec 2019 9:30am
boxoftricks
Thanks Paul. Just got around to doing this today and worked a treat. Your instructions were immense Thumbs Up Thumbs Up Thumbs Up
Post #809994 12th Jan 2020 10:09pm
PaulMc
I'm pleased that they helped Very Happy Paul.
Post #809995 12th Jan 2020 10:24pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
I’m going to follow this excellent solution too. I’m not too experienced in auto electrical so I’m wondering how I might go about neatly waterproofing the green/white 3-way splice? Any suggestions please.
Post #822006 29th Mar 2020 10:59am
boxoftricks
I just wrapped the wire splice in electrical tape. No need for the additional harness. Unless you're going through deep water on a regular basis will be fine. I've had mine up to the bonnet many a time and all works ok.
Post #827994 27th Apr 2020 3:58pm
rockster57
Boxoftricks, ok that’s great. Thank you. Most unlikely I’ll be doing much wading either. Thumbs Up
Post #828069 27th Apr 2020 8:23pm
CallumB
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
@rockster57, I'm a bit late to one but did you get this to work and did you modify it in any way? I'm just about to embark on adding power to my seat heater relays but can't help but wonder if there's a better source for the relay trigger (ignition live) when there's a huge bunch of wires right there in the driver's seat box without having to delve underneath to the gearbox????
Post #863228 23rd Oct 2020 4:11pm
