Home > Maintenance & Modifications > Spray Painting Advice |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3993 |
If you can do the work somewhere warm and dry, I’d have a go with the rattle cans. Spray paint doesn’t like cold or damp. You’ve nothing to lose, if comes out crap just rub it down and have another go. Alternatively have a go at learning to spray with a gun like I currently am https://www.defender2.net/forum/topic70880.html 2007 110 TDCi Station Wagon XS
28th Mar 2020 11:27am |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Good results are obtainable from rattle cans on smaller surface areas. I’d never consider trying to spray a door panel with a can for example. I feel you would be fine with the AC panel. Warmer days are best with little/no breeze - even if working inside your garage. As with most things, good preparation pays dividends. Not just your work piece but the environment too. Clean and clutter free. And to get a professional finish, don’t forget a clear lacquer top coat. I apply 3 light coats of lacquer and am happy with the finished result. My work in progress this morning..... Click image to enlarge |
28th Mar 2020 11:47am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2494 |
I'd certainly have a go with the rattle cans seeing that you've already purchased them and also you may not be able to find a paint shop open at the moment.
I'd have a go at painting the rear side and if you make a dog's breakfast of it then try a paint shop or as mentioned above learn how to use a spray-gun. Just remember that spray painting is a combination of both art and science and you've got to get both right for a perfect finish. At least your practising on a small surface area of a grille rather than a bonnet Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
28th Mar 2020 1:34pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 803 |
OK, thanks for the advice chaps! I’ll have a crack with the rattle cans then! It’s windy here at the minute but hopefully there should be some semi-acceptable weather next week. That’s a good idea about trying on the backside first, Discomog! Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
28th Mar 2020 2:56pm |
