Home > Technical > Folding rear bench seat release pull broken.
Swiss
Romania 2006 Defender 110 2.5 TD CSW Alpine White
Is there an easy method to resolve this issue?
The release mechanism for the single bench seat behind the drivers seat is broken.Anybody have any ideas on how to release the latch so the seat folds down and I’m able to access all the screws to fix this issue.
Post #821608 27th Mar 2020 11:29am
dorsetsmith
your pic
Post #821633 27th Mar 2020 12:42pm
miker
Can you take some more pictures? That looks nothing like the second row seats in my truck!!
Post #821658 27th Mar 2020 3:15pm
Swiss
Sure....I’ve added a picture of the good side that’s functioning.The Defender is LHD and originally from Germany.Not sure if they’re much different to the UK spec.I can take more pictures if you require.To be honest the good side does not function very well.If there’s a solution to replace both then I would probably be happier.But the biggest problem at the moment is I can’t drop the single seat.
Regards
Tony
Post #821661 27th Mar 2020 3:58pm
Nutter
Hello you should be able to use a pair of long nose pliers or tweezers down the hole and pull on the broken rod, you may have to wiggle the seat as you pull it.
Part number MWC1614 link rod R.H
Part number MWC1615 link rod L.H
Part number MWC2722 plastic ring pull
james
Post #821703 27th Mar 2020 7:53pm
Swiss
Thank you James,very helpful.
Regards
Tony
Post #821748 28th Mar 2020 9:27am
izack98
Canada 2001 Defender 110 2.5 TD CSW Chawton White
Here's the parts list. I had the same issue in my LHD 110. I tried to get down in there with a pair of needle nose but didn't know what to grasp to pull. I may be able to now that I've had it apart and know what to pull.
I had to take out all the nuts and bolts that hold on the cover (Part #1). It was a bit tricky as the seat is in the way of some of the screws. I also took out the bolts (2 bolts) that connect the back of the seat to the seat cushion. Then removed the seat cushion frame (2 bolts). That helped.
It turned out Part #7 was broken off at the top. I used a small diameter piece of cable about 6" long and looped it through part #21 and then crimped the 2 ends with an aluminum crimp and then fed it out through the slot in part #1. I replace all the hardware with stainless steel allen head bolts and nuts.
It works fine
[im
g][/img]
Post #825922 17th Apr 2020 5:32am
Great answer. Thanks for sharing. Darren
Post #825940 17th Apr 2020 8:22am
rdavisinva
It works fine
Please post up a few pictures of the fix.
Your description is good.
I have the same issue and need to fix ours.
Post #855571 12th Sep 2020 2:29am
jst
These are not simple to fix, as above, the issue is getting access to the broken mech. Going in through the seat itself is required to get access to the mech mounting bolts. Its quite a typical failure , usually the plug pull lug breaks. A pain to fix as its time consuming but it's all very simple once you are in there Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #855574 12th Sep 2020 6:36am
izack98
Swiss, I'm trying to upload a couple of pics for you but when I chose the pics it just says "Adding to Panel" and doesn't do anything more. I've searched posting pics and have followed the directions. Not sure what's up.
Post #858493 28th Sep 2020 4:58am
rdavisinva
It may be that the pictures consume too large a storage space.
Will PM you with my email.
Thanks for your efforts.
Post #858546 28th Sep 2020 1:31pm
