![]() | Home > Technical > TD5 Injector codes |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6699 ![]() ![]() ![]() |
Yes you should put the actual codes into the ECU
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
Which end is injector no 1 at? Bulkhead end or inector harness plug end?
cylinder one timing chain end
Thanks!
![]() Edit: All done and running fine |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 180 ![]() ![]() ![]() |
a quick tip, write the codes on the rocker cover with a sharpie this saves removing the rocker cover to read the codes the next time you need them. nobody is perfect but being Scottish is a start
