![]() | Home > Puma (Tdci) > Traction Control Switch |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
So it's engine started, and then 10x stamp on the brake, and not just ignition on and stamp? I know I'll forget to check this in the morning, so a confirmation on here would be well appreciated.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
FG Member Since: 01 Apr 2011 Location: Somewhere on the Swedish East Coast Posts: 63 ![]() ![]() ![]() |
I've just tried it on my 2009 90 sw and can confirm it works.
![]() /FG |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Tried that on my 2010 90, doesn't work -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 ![]() ![]() ![]() |
Also tried on my 2011 90, it didn't work so I guess it's a switch for me
Just tried it on my 2010... Ignition on, stamp away and viola, no TC or ABS!! Here's a piccie of what the lights on the dash look like after the stampathon! ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 ![]() ![]() ![]() |
Sorry for the late reply. Just got the defender back with the switch fitted at the dealership.
![]() post my11 defenders cannot have a switch run through the fuse box they had to wire it through the ecu, press the switch abs tc and parking brake light up, press again lights go off and tc and abs are engaged. (750 AED and you lose warranty on the traction control and abs driveline.) ![]() ![]() |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
the disco 3+ hill descent control (TC)is amazing, it will let you drive safely down a very steep compacted snow/ice covered road.
You control the speed of the abs by using the cruise control buttons. Brilliant bit of kit when its working... Pom |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5103 ![]() ![]() ![]() |
So is terrain response ![]() |
Doesnt seem to work on my MY11 ![]() Sorry to be thick, but how long do you wait when the ignition's on (engine running?) before stamping and how fast do you stamp. Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 ![]() ![]() ![]() |
Matt, I have tried it on my Oct 07 Puma and it seems to disable the ABS and Traction Control. I turned on the ignition, started the engine and started pumping the brake pedal straight away at a rate of two pumps per second. All 10 pumping actions were completed within 5 seconds. The ABS and TC warning lights then stayed on until I switched the engine off. With any luck I will see how it goes next weekend as I will be doing some sand driving in a semi desert area in northern Victoria which has a few soft dunes to negotiate. Depends on work though. I'll try the soft dunes with and without TC and see what happens. |
Many thanks - think I may have been too slow (or LR have changed the firmware...) Off to try it now ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Didn't work for me as that's why i went for the switch. LR said it's the post my11 defenders that changed regarding this. In addition you are no longer to create a splice in the fuse box... TC has been moved into the ecu. Anyway tried it out yesterday in the desert, beautiful doesn't struggle when it reaches the top of the sandy dunes. ![]() ![]() |
Hi Def-00 Aha - that's why I can't do it! Wondering about this mod too as we get really deep snow in Bavaria. Just to grab this opportunity - a quick "ambush" question (off topic - sorry ![]() ![]() Many thanks, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Yes I do, I found out it's a matter of changing my driving style and completely submitting to the gearbox. I read on replies to you about nudging the gear out and into the next without using the clutch, that's what I do but while using the clutch, I'll push lightly until it pops in by itself. Happens with 2nd to 3rd and back down sometimes. I don't usually use first on the road just offroad or tight steep underground parking. Oh and if the gear doesn't go in smoothly I had a few occaisons where it would pop out once I release the clutch. Good luck with getting more info from the other members, hope this helps in anyway. 2012 Fuji White 110 ![]() |
