![]() | Home > Wheels & Tyres > Tyre Size Recommendation Needed |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5129 ![]() ![]() ![]() |
Cracking Land Rover you have got there
You should have no problem with Cooper Discoverer STT PRO but go for this size 235/85/16 Defenders do not look right with smaller tyres For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Bellinghammer Member Since: 15 Jan 2020 Location: Bellingham WA Posts: 13 ![]() ![]() |
GILARION, thanks for the compliment on Drago! We search for almost two years, trying to find the right D110. We were super excited to find a completely rust free example with only 60,000 miles on the clock.
He looks pretty strange at the moment with the stock tires. 235/75s will be a big improvement, just wondering if the 265/75s will be too wide and cause clearance issues. Also concerned about the 265/75s on a 6.5” wide rim. |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 259 ![]() ![]() ![]() |
235/85/R16 or 265/75/R16 will both be fine. I currently run the 265's on a fairly stock 110 with a 1" lift and no issues on clearance and find they fill the arches nicely, though the offset on your wheels will also impact on this.
Thanks Simon! The RN wheels are the same specs as the OEM wolfs. 16'”x 6.5”, 2-3/4 offset.
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 ![]() ![]() ![]() |
Good luck with it!
I would go for 265 but not cooper, either bfg or kumho, Fabio |
If your rim width is 6.5 you might be better on 235’s, I’m running a 7” rim which is the minimum width for a 265 tire as stated on a few tyre size sites.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
Personally I would go for 255/85R16 if you can get them. A little taller than either of the sizes you have mentioned, but not too wide.
I have KO2s on our lifted outback and find them pretty finicky. I do like how they perform though. ![]() Click image to enlarge |
I have the 265 all terrains on my defender, before i had the coopers stt pro.
I do a lot of of motorway miles and long journeys from here England to Portugal or Italy and the coopers couldn't cope with it. The all terrains are perfect. If I needed new tires now I would go for the kumho MT. Fabio |
Thanks everyone for the responses so far. I’d love to see some feedback and or pics from people running wolfs as well. 6.5” is the minimum width per Cooper for the 265/75s. I do think the 255/85s would be a safer option in terms of fit all around. With that being said, I think the 265/75s would look better. Cheers! |
Here you go - more Wolf wheels than you can shake a stick at:
https://www.defender2.net/forum/topic55943...preciation Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 533 ![]() |
I’ve had 235,265/75 and now 255/85/16 - I would definitely go for the 255’s. They look better than the 265’s on a 110 as they are taller and fill the arches better. Plus they lift your gearing slightly. The 265’s look nice as they are 10mm wider, but they look small in comparison to the 255’s
![]() Click image to enlarge 2017 Range Rover L405 Vogue SE V8 Diesel #16 Land Rover 110 300 TDI |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2255 ![]() ![]() ![]() |
How far out does it make the speedo??
255/85 BFG KM3 on Blindos.
