![]() | Home > Puma (Tdci) > Which lamp guards? |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
I am thinking of getting some lamp guards for my 110, all to easy to smash the rear lenses with a trailer (already done it once) which are the best to get? Genuine seems very expensive, are the aftermarket ones also hinged? I wouldn`t mind a pair for the front as well. Do they all fit the TDCi as some I saw on ebay say "upto 2003" etc.
Any suggestions for a budget solution welcome. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
That was my next question actually, do I have to drill into my bodywork. I`d rather not but looks like I will have no choice. 2011 110 USW
I'm sure you have read this already but just in case
![]() http://www.defender2.net/forum/topic1804.html Bob |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 ![]() ![]() ![]() |
For stock type lamp guard, I guarantee you will not beat Rebel 4x4 ever. The quality of their guards is far superior to anything else I have seen out there. The bars are better spaced, thicker, better finished.
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
That's just what the stealer did to mine, drill the body and fitted large self tappers! Zinc plated by the looks of things. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
How many ruined wings do you see with bubbling around the screw heads
![]() ![]() Spend your money on a reversing camera £100-150 to prevent backing into things and aid hitching up, job done and you can also check on your load on the move ![]() ![]() ![]() |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
The plastic RDX lamp guards that use the existing lens screws will help protect the lamps. Although I've had them on Defenders in the past I've never been that keen on fixing iron grids over the lamps as not only do most of them require drilling holes they get in the way of the spare wheel, the coating comes off them and the slightest nudge against one will push the panel in. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Seconded - I've had the grid type on previous Defenders and removed them as the look rubbish after a while. The type that use the existing screws are the way forward. Saying that - replacing a light lens is cheaper than straightening a pushed in rear panel. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
