![]() | Home > Maintenance & Modifications > Xenons on a Puma |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
To replace the headlamp ??
Been a few topic on the issue,, biggest problem, to be legal, they must self level, and have a pressure wash system, so for me, not worth the effort,, fit a pair of Xenons drive lamps !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
LED Lamps are the way forward
don't forget to keep it legal you need H/L power wash and auto levelling.
![]() 1968 1/32 scale Britains 109 Pick up. |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 347 ![]() ![]() |
I take it as pun intended! |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Cibie 10DE replacement light units with piaa super white bulbs sorted ! If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Led headlamps fully e marked no auto level or wash required light is way better ![]() |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
That'll change soon too. I think as LEDs get brighter this requriement will be added. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
For now.. ![]()
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 695 ![]() ![]() ![]() |
I find led lights horribly irritating, they seem to flicker and jump around, I have done some research and it may be due to my being colour blind and the pure single wavelength light produced. There is lots of debate in the sailing fraternity regarding led nav lights as they give a false location reference when scanning horizon, the CAA FAA will not permit them on aircraft. Unfortunately the motor industry is driven by manufacturers who consider image over functionality.
Daylight running lights are not a problem as these do not act as the visual reference, because the brain gets its reference from the whole vehicle not just the spots of light. 130 Puma HCPU with an Artica 240LR Demountable Camper |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Im sure the EASA will probably allow LED lights in the future, they had a similar hard lined stance on GPS in the early days.
Im not sure about the effects of colour blindness - i know my class one medicals check for colour blindness - i have always imagined it would stop you being a pilot if you were - im not so dont have that problem. Mike |
Coko Member Since: 31 Jul 2009 Location: Searching... Posts: 29 ![]() ![]() |
Me done it :whistle:
And it just loooooks 8) Last edited by Coko on 6th Oct 2013 1:43am. Edited 1 time in total |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
WOW! where did you got those!? Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
or just fit extreme brilliance bulbs to standard headlamps at 19 quid a pair and save all your hard earned.
