Home > Tdi > Clutch replacement 300tdi
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I’m in the process of swapping out the clutch - I’m only planning on moving the box rearward enough rather than drop it / lift it. I’ve got a gbox jack with a saddle on it to keep things nice a secure.
Q is - gbox crossmember off or release the box and shuffle it rear leaving the crossmember in place? I don’t fancy having to fight the crossmember back in place having done so on a bare chassis sideways with all the space in the world and enough jacks to shake a stick at! The idea of doing an old one upside down in the rain sounds pure pish.
Post #818249 5th Mar 2020 10:03am
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
Removing the crossmember will give you a lot more working room and make the job easier. I've never had a problem removing or replacing gearbox crossmembers, i use a block of wood and a bottle jack between the chassis rails to ease them apart and the crossmember slips in and out easily.
Post #818275 5th Mar 2020 2:06pm
zippo87
It could have been that it was a brand new Richards chassis and new crossmember - was almost wincing at how much pressure I needed from the hi-lift - but if you’ve had no bother I’m good to go - I reckon!
Post #818288 5th Mar 2020 3:44pm
oneten110
The original installation for the 300/r380 combination had the gearbox bolted to the crossmember rather than to a separate bracket on the chassis. Thus the gearbox xmember is not in the typical location which may make it easier if you remove it completely.
Vaseline, and LOTS of it, is your friend. I think I used a big jar on each side of the chassis between chassis and xmember when I did mine.
https://www.ebay.co.uk/itm/LAND-ROVER-DEFE...SwdgtdB9OY It is not a Defender, it is a One_Ten
Post #818292 5th Mar 2020 4:12pm
zippo87
That’s it job done!! Xmember came out and in like a dream - rigged up a little stand for it and it was spot on. Should have seen the state of the clutch, absolutely ballsed. Great opportunity to replace some of the fasteners here and there, exhaust clamps and rubbers, rewired some electrics (also courtesy of me pulling the handbrake lead off), and bled the coolant too. Just need to sort out the wretched vibration from the back end now - going to drop the prop off and take it for a 2wd trip out! Cheers for the advice.
Post #819819 15th Mar 2020 10:35pm
shaggydog
Remember the diff lock if you have a prop off or you will be sat panicking with a box of neutrals thinking what have I done!
Or so a friend told me Whistle Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #820003 17th Mar 2020 6:03pm
zippo87
I was well ahead of you and forgot about it even before removing the prop, just sat there fuming that I’d major screwed up the job, lucky the other half suggested neutral after I came in for a cuppa! Bless her! Hope she enjoys the new slickshift it’s now got too!
Post #820098 18th Mar 2020 2:06pm
shaggydog
Makes it more interesting doesn't it!
Glad the slickshift is treating you well.
Personally, I quite like the long throw, reminds me of driving a truck.....or a signalbox. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #820245 19th Mar 2020 5:42pm
