![]() | Home > Td5 > TD5 Cuts out, long story warning. |
1. you say that your ecu back for repair have you check injector code on each injector matches the codes in the ecu program ?
![]() Click image to enlarge 2.check all long your engine loom from ECU to injectors for damaged i.e. rubbing against metal work also open cct wiring in same loom ![]() Click image to enlarge Last edited by dorsetsmith on 15th Mar 2020 4:00pm. Edited 2 times in total |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
This sounds very similar to what happened to me last week, it was the crankshaft position sensor and also the harness too, garage replaced them both and the problem is fixed now, but similar symptoms, engine stuttering and then losing power before eventually cutting out.
Good luck anyway ![]() |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3358 ![]() ![]() |
I was going to say crankshaft position sensor as well.
Try a new one. |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
I had a similar problem several years ago. Ended up to be the ECU. These were the fault codes.
(10,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (LOGGED) (10,4) GEARBOX / ABS DRIVE OPEN LOAD, (LOGGED). (10,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOA D, (LOGGED). (14,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT) (14,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT). (14,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT). (15,2) HIGH SPEED CRANK (LOGGED). (27,1) INJECTOR 1 PEAK CHARGE LONG, (LOGGED). (27,2) INJECTOR 2 PEAK CHARGE LONG, (LOGGED). (27,3) INJECTOR 3 PEAK CHARGE LONG, (LOGGED). (27,4) INJECTOR 4 PEAK CHARGE LONG, (LOGGED). (27,5) INJECTOR 5 PEAK CHARGE LONG, (LOGGED). (28,7) TOPSIDE SWITCH FAILED PRE INJECTION, (LOGGED). (31,1) INJECTOR 1 OPEN CIRCUIT DETECTED, (LOGGED). (31,2) INJECTOR 2 OPEN CIRCUIT DETECTED, (LOGGED). (31,3) INJECTOR 3 OPEN CIRCUIT DETECTED, (LOGGED). (31,4) INJECTOR 4 OPEN CIRCUIT DETECTED, (LOGGED). (31,5) INJECTOR 5 OPEN CIRCUIT DETECTED, (LOGGED). Full story at https://www.defender2.net/forum/topic22280-105.html Good luck! /Hans |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 682 ![]() ![]() ![]() |
(28,7) TOPSIDE SWITCH FAILED PRE INJECTION, (LOGGED) - this is problem
(15,2) HIGH SPEED CRANK (LOGGED). (27,1) INJECTOR 1 PEAK CHARGE LONG, (LOGGED). (27,2) INJECTOR 2 PEAK CHARGE LONG, (LOGGED). (27,3) INJECTOR 3 PEAK CHARGE LONG, (LOGGED). (27,4) INJECTOR 4 PEAK CHARGE LONG, (LOGGED). (27,5) INJECTOR 5 PEAK CHARGE LONG, (LOGGED). - this are results of the first problem (31,1) INJECTOR 1 OPEN CIRCUIT DETECTED, (LOGGED). (31,2) INJECTOR 2 OPEN CIRCUIT DETECTED, (LOGGED). (31,3) INJECTOR 3 OPEN CIRCUIT DETECTED, (LOGGED). (31,4) INJECTOR 4 OPEN CIRCUIT DETECTED, (LOGGED). (31,5) INJECTOR 5 OPEN CIRCUIT DETECTED, (LOGGED). - not a big problem, typically after starting engine with disconnected injectors or injectors loom (10,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (LOGGED) (10,4) GEARBOX / ABS DRIVE OPEN LOAD, (LOGGED). (10,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOA D, (LOGGED). (14,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT) (14,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT). (14,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT). - just some non-existing things in car (A/C, ABS, electric fan) "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
