Home > Maintenance & Modifications > Steering Column Surround Removal Help
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Any tips or advice how to remove the plastic steering column surround on the Puma? I have to fit a new windscreen wiper stalk and need to gain access. I have removed all the screws from underneath but can't seem to remove the plastic trim from the top and bottom halves.
I realise this is a sensitive area so please pm if you prefer.
Post #819433 13th Mar 2020 4:18pm
Might be easier if you also remove the trim above which is under the clocks - 2 screws
Also, if you take a look, the trim is held by going around the ignition barrel, the trim needs to be wiggled forwards to get it over this.
You have to be both brave and brutal Rolling with laughter
Post #819440 13th Mar 2020 5:05pm
Scoobeenut
Aha I hadn’t thought of removing the trim beneath the clocks, will give that a go. Yes brave and brutal I think I have been there before with the Defender Laughing
Post #819477 13th Mar 2020 8:18pm
Rolling with laughter Thumbs Up
Post #819479 13th Mar 2020 8:26pm
Definitely agree what Go Beyond said. I've been there myself and that trim piece will need to come out below the clocks.
After that you'll have no problem. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #819480 13th Mar 2020 8:27pm
There really shouldn't be any need to remove anything other than the steering wheel to remove the column shroud. I did this task recently to fit an X-Eng ignition barrel shroud.
There are six screws that hold the top and bottom halves together - four posi-drive and two torx - and with those removed both parts should be obviously loose, probably only held in place by the ignition barrel and the rubbers around the stalks. The top half needs a bit of wiggling to get it out from under the instrument cluster as there's a foam filler between the two. Darren
Post #819589 14th Mar 2020 1:37pm
