![]() | Home > Maintenance & Modifications > Softer riding 110 stw, how it make? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2505 ![]() ![]() ![]() |
I would go OME2752 in the back and OME2761(or BA2106 Bearmach) in front . Puma 110" SW
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21002 ![]() ![]() |
You may want to consider spring isolators too.
They won't be game changing, but they do remove a lot of minor bumps and jolts and combined with good springs and dampers all add up to a nicer ride. Also Dynamatting your seat boxes and Seatbox base can dampen vibration and feels a better ride. I use genuine standard springs on mine, lowered springs or HD springs will all be hard compared to STD. So can lift springs too depending on if they are soft lift springs or HD lift springs. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
Ask your friend what kind of damper he have on his rr. I have put old type of damper on my defender and it is better. Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Spring isolators will do nearly nothing on a Defender. Puma 110" SW
Castillo Member Since: 23 Nov 2012 Location: Tavastkyro Posts: 41 ![]() ![]() |
Thanks all answers. I have isolators in front. I dont know how it helps there. Not much or nothing. I have also poly puches there. They have been there about 110 000km there now. Maybe those are not good yet.
Are those bearmach and ome springs progressive springs. Whether the travel is more comfortable thanks to the progressive spring? I have driven my car 220tkm and the original springs have been there perhaps 180tkm. Are the springs already dead. How long time and much kilometres they stay good. Would the new standard spring help to provide more comfort again? These suspension things are a bit difficult. It is expensive to buy and test many ones π defender 110 td5 2006 |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
I certainly believe it made my ride quieter.... Less road noise through the vehicle from the tyres... Worth doing IMHO for such a small price tag... Castillo - this is my journey: https://www.defender2.net/forum/topic49065...oilsprings Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Interesting, thanks MartinK. Now I have to think a bit and analyze riding more. Back or front... or both is too hard for my neck in my defender defender 110 td5 2006
I measured the length of the springs in my car when it was in the park and the spring is 230mm in front and 290mm in the back. I have thought about installing (perhaps) a winch, and it increases the weight of about 35kg.
Does the D90 rear spring fit the D110. For example NRC 9462. I dont need much lift but a bit can become if it will become. Not so easy this kind of suspension thing ![]() |
I did say spring isolators would help, not be life changing. Combined with a change of spring the two can add up to a beneficial result. Then of course there is dampers. Never found Polybushes any good, worse in fact than factory. ____\We|Will|Win/___
