![]() | Home > Puma (Tdci) > Puma 2.2 110 Tyre pressure |
| htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548
TD5 Hicap towing Ifor Williams must of the time and I run 30 psi front and 45 psi rear
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
On my csw 110 I always run 30 front and rear or if towing 34 front and 38 rear never had an issue 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Definitely run the rear's lower...otherwise you'll need new fillings in your teeth when unladen
I'm 35 psi all round... Go lower and your economy suffers, go higher and your fillings suffer. I've also softened my suspension, and added KONI shocks for a better ride |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1139
Depends on weight and tyres doesn't it? Our camper Landy is about 2400kg and tyres are Conti AT.
Usually I go higher than LR's recommendation of 2.1/3.3 bar or 30/45 psi, say about 2.4/3.6 (35/50), lower on gravel roads, of course. Never perceived it as being bouncy - it's a Defender; I like it |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21039
34F 36R works for me.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697
30F and 45R unless towing with passengers then 55R
Reminds me need to put the rear back down to 45 |
| CSK Member Since: 15 May 2019 Location: St Tropez Posts: 41
Great! Thank you all for taking the time to reply.
@macfrank, I understand the higher pressure at the back because of the camper van set up you have so you have more weight at the back. In fact when I'm going on a trip and I have some load at the back, the ride is so much better. @Scotm, 45 is what I used to run at the back and I think that's way too much when there's no load. There's an English Defender specialist not far from where I live in the South of France and he recommended going for 2.5 BAR/36 PSI all round. Just ordered a Startech steering wheel and some other goodies at JE in Coventry and thought I'd ask them too, they recommend 2.4 BAR/35 PSI all round with the standard size 235-85-16 so I've settled for that and see how I get on. I've got two weeks to play with pressures before my new tyres are fitted. |
| All times are GMT |
