![]() | Home > Maintenance & Modifications > 110 Puma Rear Arch Liners |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
If it's tight under the wheel arch then the wheel shouldn't get that close
| Gillan Member Since: 01 Apr 2016 Location: Sheffield Posts: 35
What a great job if you should definitely think about getting some made up I'd definitely be interested in a set
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
Did you get any further with these bud? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323
Awesome - well executed!! Must add this to the list of things to get done...
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Great work and well done you for sharing your method, its what makes this forum!
I'm pleased to see it looks like they're relatively easy to remove for the occassional clean behind. No doubt you'll still get some crude behind it. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
I really like the look of these as well. Especially as I embarrassingly have to admit I don’t go off road. There I’ve said it “i’m Out now “
So i’m nterested in a set if they go into production. There was a mention earlier on wing stays and their weak point connection to the outer wing. I notice YRM metal solutions have a fix for this. “Defender 110 Mudflap & wing stay reinforcing bracket on outer skin of tub.” Part number 310. Also wing stays for 110 part number 215. These parts are aluminium. I think they do versions for the 90 as well. https://yrmit.co.uk/product/mudflap-wing-s...ender-110/ https://yrmit.co.uk/product/rear-wing-stay...r-110-130/ So these could assist in supporting the arch liners if the existing rear wing stays and connection to wing/tub was thought insufficient. |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
It's just a piece of aluminium you can find in any diy store. Drill two holes or three if you like, done in 10 minutes. 15 minutes if you put some EPDM or other sealant on the back to avoid dirt getting behind it Click image to enlarge |
| Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039
Great idea, i looked at lorry mudguards but so far haven't found a correct sized version.
| Irishdog Member Since: 09 Mar 2018 Location: Sande Posts: 13
Best "Home-Made" Job I've seen. Would be interested if available as a set. My TD4 is currently in Namibia, and these would help to reduce the damage done by the gravel roads.
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
That looks very smart
Any chance you could post the measurements (unless you're going to make them commercially, of course). Only thing that might be worth a mention is using Duralac or similar to insulate stainless/steel/aluminium joints from bimetallic corrosion, as it gets pretty wet and salty under there. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| wizzwas Member Since: 09 Jul 2019 Location: Buckinghamshire Posts: 12
Thanks guys, I had them off the other day and everything looked fine under the tub. Had a proper clean under there and behind the pitiful original plastic flaps covering the rear lights. So I can see how much crap gets behind there from now but there didn’t seem like that much got round there.
I’m still pretty chuffed with them. Here's the dimensions of the fuel filter side, just need to cut the corner out for the exhaust on the other. I can’t be bothered to put them into production, open source! Click image to enlarge |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
it should be possible to make a mold of the wheel arch area with suitable anchoring points then have inserts made of blown one piece plastic.
