![]() | Home > Puma (Tdci) > Yellow engine and traction control lights |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
If it helps, I've just checked on my cheapo diagnostic tool and I've got fault code P2122, which is the throttle position sensor voltage low (there's post about this already but that chap had a cruise control fault... I don't have that!)
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
In that other case I would guess that the 3rd party cruise system (which emulates a pedal) caused the throttle pedal fault.
It might be an early sign of a pedal sensor failing, but check the wiring at the pedal for cuts/damage. If it reoccurs swap out the pedal to an known good one (all Puma pedals are the same for 2.4, 2.2 and DSC 2.2). ![]() ![]() |
Thanks Martin. I'll have a good look at that. Possibly a squirt of something WD40ish (Bilt Hamber's Ferrosol) might help.
It's actually in for its MoT and service tomorrow anyway, so I'll mention it to them. |
