![]() | Home > Technical > Oil Specification |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
Short answer is no, it should be C1 spec oil only.
Just throwing in some other oil isn't what you pay the massive dealership premium for. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| kingsley Member Since: 19 Feb 2016 Location: Herne Bay Posts: 71
Thank you. I have called Land Rover customer service they are going to look into it.
Thank you, I have now contacted Land Rover as main agent saying the Castrol 0w30 oil is better than the specified oil.
Not sure if they are just trying it on. |
It's not the viscosity rating (0W30) that is the key, it's the specification/additives - the C1 bit.
2015 D90 XS SW |
Thank you, I still dont really understand, but without the C1 its no good for the engine?
For a 2.2 DPF equipped Defender the oil specification must be C1. Any other oil isn't the one specified by LR. I can't say it's "no good" but it's not correct.
2015 D90 XS SW |
Thank you.
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543
ACEA C class oils are designed specifically as catalyst compatible oils and designed for DPF equipped engines. One of the properties of C1 is that it prolongs DPF life.
E4 is classed as a heavy duty engine oil suitable for Euro V engines without particulate filters. Martin is therefore spot on - E4 is not suitable for a 2.2 with DPF Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
