Home > Technical > piston slap?
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
piston slap?
2009 90 csw, 89000 miles. driving on m3 engine started pulling back, straight to esso garage, no oil on dipstick put litre in all lovely shot to halfords, great service they put in another 2.5 litres. its running lovely as usual. but under load, up hill etc I getting knocking/clacking noise. nothing wrong still pulls like a train 70mph no probs, but don't know if the noise has always been there, and I haven't noticed, I expect abuse for running low on oil, but any other ideas please
thanks pete
Post #817801 1st Mar 2020 9:48pm
Grouse
Sounds like big end bearings / crank shaft journals / bearings to me knocking under load 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #817812 1st Mar 2020 10:15pm
Welshsurferdude
Wales
not a cheap sound to come from a engine alas specially if ran low on oil
Big Cry 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #817819 1st Mar 2020 10:39pm
landy andy
I understand that you were low on oil and there are other things top of your list, but just for your info, not long into Tdci ownership I was sure I had piston slap, or big ends gone. After a lot of worry and research I found out it was the VCV had failed, and required replacement.
Post #817834 1st Mar 2020 11:58pm
corgi1
Landy Andy whats a VCV ???
Pete
Post #817835 2nd Mar 2020 12:08am
LR90XS2011
When you say pulling back did the oil light come on? the oil light indicates oil pressure, the tdci takes about 7 litres and is designed for 45 degree angles, I expect the oil could be quite low before the pick up point is out of the oil. DEFENDER 90 TDCI XS,
Post #817845 2nd Mar 2020 7:44am
landy andy
Variable Control Valve.
It’s a very small and delicate little valve that is easily changed on the front of the Tdci engine that controls the amount of fuel.
Post #817849 2nd Mar 2020 8:51am
corgi1
I didn't think of that NO the oil light didn't come on at any point so what does that mean
Post #817853 2nd Mar 2020 9:14am
corgi1
a long shot but funnily rear demister stopped working at same time, this was all after garage fitted new front wiper stuff cos wipers wouldnt work properly, only saying this as odd things have things like fuses in common, although rear demister light still comes on on the dash - just a long shot but oil light deffo not come on at any time
pete
Post #817871 2nd Mar 2020 11:06am
Strictly it is "volume control valve", it regulates the flow of fuel from the LP stage of the fuel pump to the HP stage and by doing so effectively determines the fuel pressure in the common rail.
It is delicate, and a common cause of problems which usually do not produce DTCs due to a lack of monitoring. In fact a VCV fault is usually diagnosable by the absence of DTCs.
Post #817904 2nd Mar 2020 3:02pm
dgardel
Italy
mhmm due to oil consumption, check if the injectors are tight and/or Injectors copper seal are in good conditions (good diesel injection workshop) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #818072 4th Mar 2020 12:32am
