Home > Technical > Should I have play
dioliahary
Should I have play
Overhauled and rebuilt my swivel ball and associated parts. All nicely put back together but I noticed vertical play on my swivel (not a lot) no horizontal play and it’s the whole swivel that moves slightly, not the bearings I have the track rod disconnected. Is this normal? 1990 200tdi conversion 90
Post #817566 29th Feb 2020 6:37pm
I don't quite understand what you're describing, but whatever it is it shouldn't be doing it. There should be no play in any direction in correctly set-up swivels.
Post #817569 29th Feb 2020 7:11pm
dioliahary
Hands at 6 and 12 o’ clock on wheel hub, slight movement in the set up, not sure what is incorrect, maybe take a whim out? 1990 200tdi conversion 90
Post #817578 29th Feb 2020 7:35pm
dioliahary
Sorry need to clarify swivel the swivel housing 1990 200tdi conversion 90
Post #817580 29th Feb 2020 7:47pm
dioliahary
Sorry need to clarify swivel the swivel housing, if I grab at 6 o’clock and pull the housing (as if checking for play) there is a slight movement but only when pulling the bottom and pushing the top, very slight.
I wonder if I need to change the bottom swivel bearing pin 🤨🤨 1990 200tdi conversion 90
Post #817582 29th Feb 2020 7:53pm
dioliahary
I had to use lots of shims to get the preload correct (4.5 kg). Lots 1990 200tdi conversion 90
Post #817598 29th Feb 2020 9:01pm
There should be no play. If the hub is on, make sure you're not feeling movement in the wheel bearings rather than the swivel.
Post #817599 29th Feb 2020 9:03pm
dioliahary
Hub is on, not bearings, all new parts as well 1990 200tdi conversion 90
Post #817601 29th Feb 2020 9:07pm
dioliahary
Post #817606 29th Feb 2020 9:11pm
jst
Swivel play 12 and 6 is king pin bearings or shims incorrect. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #817642 29th Feb 2020 11:37pm
donmacn
Apologies if I'm talking pants here.... Embarassed
If I'm seeing it right, your picture seems to show that the swivel seal, and its retainer is in place. In this case, when you're measuring preload, you are having to overcome the resistance of both the pin bearing and the seal.
My Workshop manual isn't to hand, but I thought it said preload should be measured for just the bearing - with no seal in place?
My logic then tells me that you could be shimming the pin to get the right preload, but the seal tension is putting your readings out.. So, the preload would read OK, but the pin would be too loose and giving you the movement you're describing.
As I say, could be complete pants... It's just something I dimly remember from when I last did this job.
If I've got it wrong I'll hang my head in shame for 5 minutes... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #817674 1st Mar 2020 9:43am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Donmacn you are correct in thinking the rear swivel seal should not be fitted at the time of testing.
Have the bearing seats and bearings fitted correctly? I have seen people reuse the races due to being awkward to remove and fit, with new bearings and this has resulted in problems. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #817682 1st Mar 2020 10:17am
dorsetsmith
setup with swivel housing seal not in place Exclamation
(I had to use lots of shims to get the preload correct (4.5 kg). Lots ) Question are you checking preload with seal in place if so you are not checking reload on top and bottom bearing but amount force to move seal over swivel ball Exclamation
Post #817690 1st Mar 2020 11:26am
dioliahary
Makes sense thanks, guess will have to preload using ‘feel’ now? Dont want to lose all my one shot 😂 1990 200tdi conversion 90
Post #817704 1st Mar 2020 1:05pm
dioliahary
Thanks all (new races as well as bearings fitted).
The problem was too many shims. Removed till play went then built shims up so I got the correct preload. The seal was giving me a false preload. Brilliant thanks for your kind words of wisdom 👍 1990 200tdi conversion 90
Post #817743 1st Mar 2020 6:21pm
