Home > Puma (Tdci) > Strange noise when turning.
spudfan
Ireland
There is a strange noise in the Puma. (It is not the wife talking). I get a "whu,whu,whu," sound when the steering is turned to the left (passenger side). It disappears once I straighten up the steering. Power steering fluid level is fine and I do not see anything rubbing. It sounds like it is coming from the front wheel area. Any ideas? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #817241 27th Feb 2020 4:58pm
Huttopia
Is there a blue flashing light behind you? 😆
Post #817261 27th Feb 2020 6:55pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Mine did that, always at very slow speeds turning left. I changed the pas fluid last year and its much better now. 1953 80"
1987 mini city e
2011 90"
Post #817281 27th Feb 2020 8:48pm
spudfan
Ireland
Interesting. As far as I know the PAS was changed a few years ago but it is worth a try. Thank you. Thumbs Up 1982 88" 2.25 diesel
Post #817286 27th Feb 2020 9:01pm
Merlin
If you have a steering guard, it could be that rubbing on the steering arm. A bit of pounding through ruts and they bend the guard. Peter
Post #817365 28th Feb 2020 11:07am
Simon1979
Wales 2006 Defender 110 Td5 Silver LE Zambezi Silver
I have exactly the same noise but in the drive side. Did you find out what it was?
Post #900283 27th Apr 2021 8:43pm
spudfan
Ireland
Nope. It is very infrequent and hard to pin down. It cannot be anything serious as the vehicle was through the annual test (your MOT) and I got no notifications about anything needing changed and they shake the living daylights out of it on the machine. Probably sometime in the future me or the garage will find out what it is but I do not worry about it. If there is an almighty EUREKA moment and I find out what it is I will let you know. 1982 88" 2.25 diesel
Post #900290 27th Apr 2021 9:07pm
Co1
I had more of a squeak when turning in one direction. Turned out to be the seals on the steering damper had gotten dry. A bit of silicon lube and all was quiet again and has been for the last year or so.
Post #900312 28th Apr 2021 4:59am
trailbear
I had that very issue on my last Defender, changing the Power Steering fluid solved the problem for me.
I think there was air in the system, it only happened on turning to the passenger side.
I had changed one of the PAS pipes ( because of a slight leak / rusty pipe ) and changed
the fluid at the same time.
It solved the problem for me, changing the fluid and bleeding the system properly may
Solve your issue.
Post #900347 28th Apr 2021 10:18am
spudfan
Ireland
Power steering fluid has been changed. 1982 88" 2.25 diesel
Post #900353 28th Apr 2021 11:03am
