![]() | Home > Puma (Tdci) > Advice with heated front screen? |
No, there isn't a dash warning light for the front heated screen. Only the telltale on the button. Darren
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
As LRA says, only the orange LED on the button itself. If this is on, the timer and relay are providing the 12V feed to the screen.
Just take a cup of very hot tea into your truck, hold it close to the windshield to let it mist up, and see if you turn on the heated screen if it will demist quickly. Do this test in a few spots left to right as it is known that sometimes certain portions of the electric heating wires inside the screen will fail. You can afterward even still drink your cup of tea if you like.
![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
put the tea at one end so you can see the difference between the working part and the edges of the screen where there are no wires!
how can you live in the UK and not know if its not working through not having the need! snow and frost here testing mine currently. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 ![]() ![]() |
![]() I’m going to do the tea test! As yes the putting does light up and go out after about 10 minutes |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
Surely it could be tested with a multi-meter? Or, is the current draw not enough to pick up?
Quite big current draw that heated windscreen. An electric guzzler really.
CSK Member Since: 15 May 2019 Location: St Tropez Posts: 41 ![]() ![]() ![]() |
Will check if the heated screen works upon departure from the French Alps on Saturday early morning.
![]() Never had the opportunity to check before in St Tropez! ![]() ![]() Click image to enlarge |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Heated screens are good, but perhaps not that good
