Home > For Sale & Wanted > [Wanted] LT230 centre diff wanted
Oldowner
Anyone got an LT230 centre diff (or just the diff housing) spare in good condition for sale? Earlier td5/tdi type,
Thanks
Post #802759 19th Nov 2019 12:18am
I have one of the last type, new take out, never been used, you could have for £50 plus p&p. Not quite what you're after, but they do work (and it would cost you a touch over £1620 from Landrover Shocked )
Post #802764 19th Nov 2019 12:55am
Oldowner
Thanks,
I’m after the earlier type up to td5 - mine has suffered a failure of the crosspin and the diff housing is damaged internally. I’ve got new gears and hd crosspin but am not happy using the casing. Stripped my spare lt230 and found it has been shoddily rebuilt in the past and one of the taper bearings has spun on the diff shaft.
Might end up putting in an Ashcroft ATB if I can’t find a decent used one.
Post #802770 19th Nov 2019 7:48am
klacinak
Hungary 1999 Defender 130 Td5 HCPU Coniston Green
Hello,
does anybody now that the LT230 centre diff shafts plus housing for the 2007-2016 version are compatible 100% with the 1999-2007 version?
I only need the diff housing as the planet gears has bitten the inside surface very strong.
Of course I will pay all packing and postage costs.
I have an LT230 81D type.
Thank you so much!
Post #817110 26th Feb 2020 9:16pm
Yes, they are interchangeable.
Post #817124 26th Feb 2020 10:11pm
