![]() | Home > Puma (Tdci) > is it me |
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
I think I know what you mean. When I took one for a test drive a few weeks ago I found it necessary to alter my gearchange technique a little and make sure I was off the accellerator a wee bit sooner when pushing the clutch in. I think the fact that it is a freer revving engine to the Td5 or Tdi makes it spin up when the clutch goes in if you're not right off the gas. 2007 Defender 110
1970 Alfa Romeo 1750GTV |
One other solution might be to get the clutch adjusted down a bit so it disengages a tad lower. I presume the clutch pedal mechanism is basically the same as the Td5 so probably one turn of the pedal adjustment nut ought to do it. 2007 Defender 110
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
I think there is a software up grade for this problem.
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 287 ![]() ![]() ![]() |
Thanks, I'll have a word with my dealer, does your defender not suffer from the same ploblem
![]() Carpathian 110 also sold Defender 110 camper now in build |
No neither have this issue. I will ask 10forcash on the disco3 site for the info as he was the person that advised my of this issue in the first place. |
Thanks Andrew, I'll hang on before going to the dealers JE Zulu 110 now sold
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Not noticed it with mine
![]() I thing i have, which i presume it connected with the anti-stall, if you take the revs up to 1500 say, whilst stationary, and then hold, revs will drop back to tick-over in about 6 secs !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Mine started doing this today, also got jammed in reverse and wouldn't free for ages, oh and it is leaking like a good 'un in the passenger footwell ![]() |
Now that I have my vehicle I can confirm that it does blip the revs a couple of hundred RPM on each gearchange. I am still getting used to the feel, but so far I haven't worked out a technique for avoiding this altogether. If I try backing off the throttle sooner I usually get a bad, jerky gearchange so that's obviously not the solution. 2007 Defender 110
Milligan Member Since: 07 Dec 2007 Location: Somerset Posts: 32 ![]() ![]() ![]() |
I've experienced the same thing and not been able to stop it happening however I try and drive when pushing hard. If anyone has had a fix applied etc., it would be good to have more detail before getting the dealer involved.
Been using a 06 year 90 for the last few weeks, but jumped in the 07 yesterday for a trip to Torbay,, !! a total pleasure compered to the TD5
Maybe i have a good one, as no gear change issues, nice and smooth, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
I have actually noticed that with harder driving (changing at 3000RPM instead of 2500RPM) this doesn't seem to happen as much. 2007 Defender 110
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
I have just read this post and having owned my Puma TDCi for over 6 motnhs now and 12k miles I know exactly what people are talking about. It is quite hard to change gear smoothly with the new set up and I am convinced it is something to do with either the anti-stall or dual mass flywheel setup (that has been reported to fail in the Ford Transit). The technique I have predominently been using is not to touch the accelerator at all until the clutch is fully depressed for all gears other than 1st. This seems to work quite well for me. Another thing I have noticed is that you cannot start to accellerate slightly until the clutch is fully depressed when gearing down also as this causes a jolt in the tranmission.
Regards Rich PS nice site especially with a dedicated Puma section. |
This is a known fault and is a warranty fix via a software up-load, have a word with your dealers
