Home > Maintenance & Modifications > Door Seals
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Door Seals
All, Looks like my Door seals have gone Hard and started leaking onto my carpets (Its already been dumdumed)
Looking at replacements,
Any of you used Exmoor trim ones?
https://www.exmoortrim.co.uk/front-door-seal.html I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #816702 24th Feb 2020 12:32pm
Balvaig
LR originals are the best replacement, and keep the water out - but expensive.
Post #816707 24th Feb 2020 12:39pm
OsloBlue
yeah not going to pay £80 a seal for something that has already gone hard and won't work... I'm on IG: https://www.instagram.com/osloblue42/
Post #816710 24th Feb 2020 12:47pm
Balvaig
If the hard seals are as originally fitted then they have lasted 15 years. Aftermarket seals tend not to fit properly and leak and will fail much sooner.
Not tried Exmoor trim ones though.
Post #816727 24th Feb 2020 1:59pm
OsloBlue
the Seals on mine are Genuine LR only fitted 2017... I'm on IG: https://www.instagram.com/osloblue42/
Post #816729 24th Feb 2020 2:06pm
Balvaig
Yes I can see your problem then and reluctance to spend on original. Mine are 4 years old and still fine.
Hopefully others will have used the ones you have seen and will comment.
Post #816743 24th Feb 2020 4:52pm
hopeydaze
United Kingdom 2006 Defender 90 Td5 SW Cairns Blue
Slight thread hijack. What do you recommend using to attach the seals?
Post #816778 24th Feb 2020 8:33pm
grafty99
A hammer and a block of wood works well Thumbs Up
I've only just replaced the genuine seals on my 2002 90 (still serviceable but tatty) and the ones on my 25 year old 110 are tatty but haven't gone hard yet either (will be replaced soon)
You may have been unlucky with a bad batch. I've never heard anyone say anything good about aftermarket door seals - especially britpart ones Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #816781 24th Feb 2020 8:46pm
Balvaig
Agree - for original seals I used a rubber hammer. They have a metal insert that grips the door frame. Nothing else needed.
Post #816807 24th Feb 2020 10:47pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Having had a bad experience in the past with aftermarket seals, I would say genuine are the best, I binned the first lot I bought as they were useless and didn't fit properly. The genuine ones were superb and you could really see and feel the difference in quality and they fit straight on, but pricey yes...
Post #816833 25th Feb 2020 8:33am
bankz5152
If its a 110 use genuine rear seals nothing else fit.
Front door seals Ive had good experience with Exmoor ones.
Post #816834 25th Feb 2020 8:37am
OsloBlue
Rear seals are fine, front is different I'm on IG: https://www.instagram.com/osloblue42/
Post #816930 25th Feb 2020 8:37pm
bear100
Been there loads of times and genuine is the way forward.
That do their job well Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #817013 26th Feb 2020 10:01am
L110CDL
I have replaced my door seals with the genuine ones not long ago after all on this forum recommended they are the only ones that will do the job properly Thumbs Up
If your still not decided on which ones, look at the video's that Britannica Restorations ltd do, a good way to find out the good from the bad Thumbs Up Clayton.
Keeper.
Post #817451 28th Feb 2020 10:05pm
