Home > Maintenance & Modifications > Halo Drls..
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Halo Drls..
Evening...got a work colleague thats recently purchased some of those Halo Headlights that also have the indicator. Now he wants to know where under the bonnet he can find a live for them.
Can you help him ...its a Tdci.... Putting Dreams on Drives at JLR Solihull..
Post #816601 23rd Feb 2020 6:13pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
The appropriate Live is the feed for each headlight or indicator or sidelight element that he wants to pick up, so indicators need chipping in to the appropriate loom on each side.
If you want the DRLs to come on with the ignition then you need an ignition live. I believe that there is an IG live that runs to the heater motor but best to have a look on a wiring diagram.
Post #816679 24th Feb 2020 10:04am
benniferj
This thread: https://www.defender2.net/forum/post628236.html
This Bit:
Quote:
I mounted my DRL controller on the left hand wing.
I routed the 12v trigger wire to the blower immediately adjacent.
there is a Orange / red wire from memory that is a ignition live wire.
I just tapped into that.
The DRL is pulling milliamps, and the blower wiring has plenty of headroom for the additional pull from the DRL controller.
All above is fused at source, so really very little risk.
Food for thought.
Andy
Post #816680 24th Feb 2020 10:06am
adafish
Cheers will let him know. Putting Dreams on Drives at JLR Solihull..
Post #816683 24th Feb 2020 10:16am
discomog
Heater motor is an AUX live and not an IGN live Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #816689 24th Feb 2020 10:48am
Martin
Site Admin
Indeedy.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #816694 24th Feb 2020 11:19am
Mo Murphy
If he runs the ignition live for the DRLs through a normally closed relay and then triggers it open with the sidelight feed then the DRLs will switch off with sidelights.
HTH
50 Shades of Pennine Grey
Post #816708 24th Feb 2020 12:42pm
