Home > Technical > 13pin towing socket installation
Oldowner
I have got to fit a genuine 13pin LR005919 towing electics kit to a 2012 90.
The 90 has already got a genuine 7pin kit which was dealer fitted into the recess in the rear crossmember instead of the usual bolt on brackets. Are 7pin and 13pin sockets the same bolt / screw fitting? Once the old 7pin has been removed can the new 13pin fit in this recess?
Thanks
Post #816499 23rd Feb 2020 8:13am
Martin
Site Admin
Very short answer - yes!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #816500 23rd Feb 2020 8:22am
LR90XS2011
I know you can get adaptors but I doubled up on mine so I have 7 pin and 13 pin allowing me to tow anything without a 13 to 7 adaptor. Hence can tow a caravan or 7 pin trailer.
Be careful to check the 13 pin kit is for a caravan if you intend to tow one and hence has all the supplies you need I brought a genuine kit and it didnt have the permanent live for the fridge, charging and ATC, so ended up selling it on and getting a maypole kit and splicing into the 7 pin loom and using the purple permanent live and a VSR for the caravan supplies, same applies to a horse box you may want internal lights etc fed from the LR DEFENDER 90 TDCI XS,
Post #816506 23rd Feb 2020 9:11am
discomog
Same advice as LR90XS2011. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #816511 23rd Feb 2020 9:32am
Martin
Site Admin
The genuine LR kit LR005919 does have the permanent and ignition feeds.
Source: there’s one fitted by me on my 2.2 90 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #816512 23rd Feb 2020 9:37am
LR90XS2011
Excellent thanks Martin DEFENDER 90 TDCI XS,
Post #816516 23rd Feb 2020 10:30am
Oldowner
Thanks should make it a reasonably easy fit
Post #816634 23rd Feb 2020 9:42pm
