![]() | Home > Puma (Tdci) > It just won't start... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Try running a cable from the +ve of the battery straight to the spade terminal on the starter? (or probably easier to connect to the spade on the starter then dab it on the battery..)
that way it'll bypass any ignition wiring/relays etc (making sure the ignition is switched on first so it'll start) |
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Check the earth strap on the engine too Hold my beer and watch this!
