![]() | Home > Td5 > TD5 Rev counter bulb |
| boode Member Since: 11 Apr 2012 Location: Devon Posts: 436
I have just replaced all of mine with this kit
Much cleaner light Need to order an extra small bulb for the rev counter - you need 5 of the stick bulbs https://www.classiccarleds.co.uk/collectio...s-509t-286 |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3325
Not many TD5’s have the Rev counter, l don’t think it was ever a standard fitting and to buy they are around £300
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
It's a 286 code bulb, 12V 1.2W, all the small Td5 instruments use the same except the clock which has onboard LED.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161
They were only standard on the SA spec 147. The defender has migrated, leaving the owner behind. |
| OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825
Were these not an XS standard option. I have one thank god. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
No, never standard on UK models AFAIK.
2015 D90 XS SW |
Oh cool, thanks for that clarification martin.
Interesting that its considered an option. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
| Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587
I replaced almost all my dash bulbs with white LEDs from eBay a while back. The exception was the clock which has PCB mounted LEDs. The upgrade of these has been covered in this forum but I've yet to do it.
https://www.ebay.co.uk/itm/183075105394 The rev-counter is visible in this photo (albeit out of focus because the photo was intended to show the effect of the main-beam LED bar behind the aircon grille) but it shows the illumination. Click image to enlarge Click image to enlarge |
