Home > Maintenance & Modifications > Right, undersealing! Sorry but.....
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Right, please bear with me.........
I want to get my new DC undersealed, and really do want to do it myself. The small problem is that I've never undersealed a car before in my life, although been under them more than a few times! I've searched on here (my word, I've searched!), and for a complete beginner in the 'art', I can't seem to find any type of instructional guide (for want of a better description).
Is there such a thing, or is it purely a case of old clothes, sheet down, jacked up, wheels off (probably) and get in there, covering anything that looks like it might rust at some point? I've seen the 'water ingress' manual that was posted up by Zag recently, but I can't see that it relates entirely to what I'm aiming for......
I've managed to find a few snippets of information, such as removiing bungs for jacking points in front of the chassis, grommets near wipers, and the black paper sticker under the bonnet on the bulkhead, but thats about it. Any lists of things to remove to get into/behind, etc?
Are there any 'bits' that you would keep the Waxoyl/Dinitrol away from? Obviously the brakes & exhaust/engine, but anything else, or is it all fair game? One thing I was thinking about was the 'filler' caps (can't think of the proper name atm) on the diff's, do you ust cover straight over them, aswell as other nuts/bolts, etc?
Sorry, but my eyes are stinging after trying to find the information for myself!
Bow down Mark
2011 110 XS DC
Stornoway Grey
Post #81538 22nd Jul 2011 10:24am
mse
Obviously the underside needs to be clean
I know Mr Dinitrol will be on shortly - but i prefer waxoyl - but used in the right way - there are the three types...black tin is underbody seal, maintly the exterior - certainly the high traffic impact areas. Yellow stuff is really low traffic and internal sections and obviously the stone chip guard (i applied under the main coat in high impact areas
Removing wheels etc is good...cover key components if your doing that and spraying and its your first time. I didnt cover any part on my last defenders and got 0 oversparay
Helps if you can raise all the defender (not essential) then if you can get one end higher great.
I paint with a bursh the underbody seal - takes 1/2 a day to a day to do that properly when you know how on a 90. Then the compressor to go over all the other hard to reach external sections - i deliberately overspray the hand painted painted section again 1/2 a day to a day
Tip on ALL of it - heating it up is needed, sun heat is the best, but any form (hot water bucket is another one) i add a cap of white spirit in no more, colder you may need more
For internatl sections, common sense really - a carity spray is useful, i had a lot of success with the hand pump waxoyl tool - just aim for every hole you can see on the chassis in a systematic way. Note the circular cross member - outriggers and rear cross member.
Take the front bumper off and get in the front of the chassis
There are 4 holes at the bottom of the bulkhead (2 outside, 2 inside) you can stick your probe up and give it a hudge spray - you can also remove the top bolt on the door (whilst closed and insert your probe there)
WIndscreen bungs out an get involved there
Get in above the tank and around the top of the gear box/tbox etc
Engine bay there are some access challenges - especially with a brush but it can all be done
Various bits you can remove i cant recall - but be systematic with nice warm flowing fluid (either spray and paint).
Expect to revisit the car after a day or so and fill in the gaps you have missed.
Leave it to dry for a day or so - be prepared with a mask - WD40 removes it from you just as well as a car Wink
Just take you time, be methodical and think about the different areas. Mike
Post #81550 22nd Jul 2011 12:41pm
MuddyMarky
Mike,
great answer, thank you. Pretty much exactly what I'd hoped for Thumbs Up I assumed a common sense approach would serve me well, but its good to get tips etc from someone who's done the job.
I've looked at some kits that are available (Dinitrol kits really) and wondered what the bungs are for? Are they to replace the original ones, or to plug holes up that shouldn't get the sealant in them? Mark
2011 110 XS DC
Stornoway Grey
Post #81554 22nd Jul 2011 1:39pm
Happyoldgit
I think I've just lost the will to live Wink I've done loads and have posted up some examples of rustproofing various vehicles in the past, I think there's still one in the tech archive on LR4x4. The most important thing is to use a bit of common sense, keep the stuff away from sensitive components such as some kinds of rubber etc. I gave up heating he stuff [used to use a tin with a kettle element let into the bottom] as the stuff cools down as soon as it leaves the gun anyway - nowadays I just thin to suit the product and ambient temp.
Make sure the vehicle is as clean and dry as possible. Get the vehicle up on axle stands, wheels off, plastic bags tied over the hubs to protect the brakes. Mask off other bits you don't want to cover [for example the exhaust up at the hot end]. Wear goggles, mask, hood or hat and a boiler suit and work methodically around the vehicle and once you've done that go over it again from another direction and so on. To do a proper job will take a while but the time gets less the more vehicles you have done. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #81556 22nd Jul 2011 1:44pm
Zagato
Here you go Mark the link to the correct Dinitrol kit £97 +vat , they will also give a work sheet for a 110 if you ask Thumbs Up
http://www.rejel.com/rejel-store/list/1/productid/9408.aspx
It also comes with a can of acid rust convertor to just treat any bits that are starting to go before you plaster it all. Takes 2/3 hours max, no need to heat anything up, jack anything up or take wheels off etc. The sprays are pretty accurate. Took me half an hour each side underneath and then doors pillars etc on top. As others have said max 2 hours really Thumbs Up
Waxoyl, as said from an earlier posters experience can bubble and ripple some rubbers, plastics (He ruined his new door seal before he stopped Sad ) so there is less need to be concerned about what you are spraying with Dinitrol. I made my tyres and my fathers tarmac driveway bubble when I used the stuff first 15 years ago Shocked but fortunately it went down but my rubber door seals didn't on a the SAAB Sad . Doing a quick google will show you that Waxoyl is now a dated product in tests compared to what is on the market now Thumbs Up See Practical Classics test where Dinitrol comes out best and hear for the Bilt Hamer test Sad
http://www.bilthamber.com/pro-introduction.php?cname=Corrosion Prevention&name=dynax S50
I have linked to some before - practical classic test being one off the top of my head. One draw back is that it can simply slide down the sides in hot weather not covering anything in wax just white spirits - this has all be well known for years amongst those within the classic car scene...
It's a satisfying and easy job, you will work out what to avoid when you are underneath, trickier jobs are sealing windows which is best left to your local fitter - very messy and fiddly.
Post #81560 22nd Jul 2011 2:12pm
mse
talk about stating the bleeding obvious Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
In answer - just ignore the rubber bungs - serve no point. Your looking to warm not heat the stuff and its dead simple to do unless your waxoyling in the artic. The sun keeps it thin and meands you get good coverage
I hear a few points about waxoyl ruining rubber - if you want to see my discovery (where not giving a sh*t when spraying) you will see it doesnt hurt the rubber Thumbs Up
As zag does mention, there isnt a need to jack anything - but it makes like easy...and keeps you cleaner Mike
Post #81561 22nd Jul 2011 2:12pm
Zagato
mse wrote:
Quote:
From Miserableoldgit - To do a proper job will take a while but the time gets less the more vehicles you have done.
Rolling with laughter Pass me your wooden spoon MOG Wink
Post #81563 22nd Jul 2011 2:26pm
Happyoldgit
That may be so it's sometimes a requirement around here Whistle Steve.
Post #81564 22nd Jul 2011 2:35pm
Zagato
Ah that's to good an answer Sad Your no fun MOG Laughing I'm going to read my book now Big Cry
Post #81566 22nd Jul 2011 2:40pm
mse
usually for the more simple of folk Mike
Post #81572 22nd Jul 2011 2:57pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I always do my own.
there are a couple of photos on this thread i think.
http://www.defender2.net/forum/topic1685.html?highlight=underseal
Post #81582 22nd Jul 2011 5:49pm
MuddyMarky
Thanks for all the advice chaps. Last question then* - how long does it last for, or do most of you just check it a couple/few times a year and 'touch up' where needed?
*this might not be an entirely true statement Mark
2011 110 XS DC
Stornoway Grey
Post #81598 22nd Jul 2011 8:26pm
Happyoldgit
Lots of variables involved there as it depends on what you've used and kind of use the vehicle has had. Check exposed areas that are likely to get abrasion once a year at the end of the summer and before winter sets in will usually suffice. Steve.
Post #81615 22nd Jul 2011 11:05pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
well i have a couple of jars with a paint brush let in through the lid and then full of black or clear waxoyl, that way i can just touch up whan i see a spot, full job seems to need doing once a year, well thats my time table.
Post #81616 22nd Jul 2011 11:07pm
Zagato
Waxoyl have said every two years for their "original" cavity wax stuff. I think some Waxoyl applying businesses guarantee for 4 or 5 years but that maybe for the under-seal stuff which is stronger. When I used it I had to re do it every year. It's all dependent on the type of use the vehicle gets, for example Dinitrol say that if you are wading regularly the cavity wax should be done every two years and the under-seal could need a touch up every year. They suggested for my type of use ordinary road use that I wouldn't have to do anything for 4/5 years.
There are other products on the market, Bilt Hamer for instance which similar to Dinitrol is used by car manufacturers, Somebody said Porsche use Bilt Hamer. They have also done a test on the various products - Waxoyl came out last again.
See hear & scroll down http://www.bilthamber.com/pro-introduction.php?cname=Corrosion Prevention&name=dynax S50
The very best thing to do is paint with POR-15 which will protect your chassis externally, axles etc for life.
It's marvelous stuff http://www.frost.co.uk/automotive-paint/po...paint.html but obviously can take a couple of days to do properly. I did mine over a week due to neck ache then sprayed in the Dinitrol cavity wax and under-seal, shame it was all nice and shiny from the paint then it got plastered in Dintrol but protection is more important than a shiny bottom Shocked
I'll copy this from another thread so we don't have to keep repaeating it all in the future - can just put a link to this thread Thumbs Up
Spray the underside (nooks and crannies, as said!) relevant mechanicals and use the extension nozzle for the chassis insides, rear cross-member, door pillars, bulkhead front and inside, doors, etc, and other sprays, sealants for under ALL the capping's, between the body joins e.g. window and bulkhead seals, main body and sides, sides and roof. Also around the unpainted rivets, front window hinges, bonnet hinges, gutter seams, mirror arms, rear window catches, wiper arm exit points, both water jets, lower ali front panel, steps etc etc and do the interior seat frames/brackets that rust from the outset any nut's bolts you can see and those under the carpets etc and lower seat belt fixing as they can rust within the year! and in and around the bottom rivets holding the lower door seals in place under the rubber etc (not with Waxoyl though it will ripple them out of shape!), headlight rims, and all the external front screws etc etc Oh and door hinges, under the bonnet, cylinders, brackets, electrics, common rail etc etc, avoiding the belt and pulleys!
Too much to detail but it's simply a case of going around the vehicle methodically and either using an underbody anti-rust stuff for bit's you won't see e.g. Dinitrol and stuff like Wurth Anti Corrosion Wax & ACF-50 for the bits you do (one remains a wax the other remains greasy!) & a windscreen sealant and a pot of Dum Dum will see you right for everything else. Where to put some Dum Dum, sealants etc are listed in the Water Ingress Manual https://www.defender2.net/gallery/albums/us...cedure.pdf It's a satisfying job as well Just need to get underneath down and dirty and I suggest you wear a mask and overalls. Window sealant is best done by your local window fitter as it's a messy tricky job Thumbs Up
You don't have to do any of this of course but you will have water sitting under your window rubbers rotting away unseen, probable leaks and rusting of pretty well everything underneath the body - not a problem if you are not going to keep the vehicle long term of course. The Defender is the only LR in the range that is NOT undersealed for protection!
To summarize this kit http://www.rejel.com/rejel-store/list/1/productid/9408.aspx
and a couple of cans of this http://www.acf-50.co.uk/acf50.htm
and call in your local window fitter to seal your windows will do the job Thumbs Up Can be done in day Thumbs Up
_________________
2011 Defender 110 XS, Elektra
1962 IIA 109" daily drive, Ursula
1968 IIA 88" rebuild, Domino
1962 SAAB 96 2 Stroke
Post #81637 23rd Jul 2011 8:05am
