![]() | Home > Off Topic > Any electricians out there? |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1051 ![]() ![]() ![]() |
We are experiencing some weird electrical issues in the house;
- Reading lamps switching themselves on/off rapidly even though they are switched off? - Fan oven, keeps switching itself on (fan noise) when everything is switched off? - all lights flicker when on? - switched on washing machine, made a few weird noises, then drained itself and switched itself off, after about 2 minutes from starting? - microwave making strange sounds when in use? any ideas chaps? Jumped ship to reliability - Mitsubishi L200 Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Thanks Rashers for the heads up, no idea about PME supply, but called UK Power Networks, they are sending someone, they too think its an earthing issue
![]() Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3648 ![]() ![]() ![]() |
That's what it sounds like. Glad you got someone who knew what they were talking about
![]() School time! PME or TN-C-S is a type of earthing system which is favoured by most supply companies as it in essence uses a combined neutral and earth supply cable into the consumers property. It is split at the consumers fuse next to the meter. In some instances, if there is a fault on this combined neutral and earth cable, it can cause a whole shed load of issues. Odds are, your electrical supply is from overhead cables and storm Dennis has probably caused the fault. |
ak615 Member Since: 22 Aug 2018 Location: essex Posts: 193 ![]() |
You could also ring Most Haunted
My mate said I should call Derek Acorah or Yvette Fielding
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
You’d need Derek Acorah to speak to Derek Acorah now because he’s one of the ‘departed’ 😳
