![]() | Home > Td5 > Overhaul |
If it’s that apart, check the dual mass and possibly replace, new clutch obviously, the removal will give you access to the rear crank seal so you can do that. You really can go mental but if it isn’t broke why spend the time and money, some things like clutch etc do make sense but pulling a head off if it has no problems ? I would leave it and just do it if something happens.
When Buggsy had an engine swap I did the oil pump sprocket bolt, rear crank seal, clutch pack, new loom, and that was about it, when she started to be difficult to start I did the injector seals with the engine fitted no problems and when she sprang a leak I could do the fuel rail pipe easily enough also. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 925 ![]() ![]() ![]() |
Yes clutch and flywheel are definitely on the list. I don’t think they’ve ever been changed.
I do agree with the “if it ain’t broke don’t fix it” mentality. It just seems like a good opportunity to replace anything that is easy to get to. The head is the main thing I’m 50/50 about. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2769 ![]() ![]() |
It’s all fairly easy to get to even when the car is built up, so I wouldn’t do anything that doesn’t need doing. At only 160k it shouldn’t be anywhere near worn out unless it’s been abused.
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Be interesting to hear from those that have an AMC head, see if its worth it.
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
Mine was as only paid £100 for it including injectors, taken off one with knackered bottom end. Have had the landrover one crack twice, welded once and then replaced with the AMC one, due to diesel in the oil trick.
I’d be interested to know what the likelihood of a standard LR head cracking is. You hear about it enough but obviously you don’t hear about the ones that haven’t cracked. Charlie
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Honestly, I've seen Td5s do 300k without the head ever being touched. If it was mine I'd stick a clutch,flywheel, water pump, injector seals and harness in it, change a few gaskets that are a pain in the butt to do when it's in and keep it going. You could spend thousands on it only for some kind of mishap to happen to it 100 miles afterwards......
160k is absolutely nothing on those engines
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
As said above don't over think problems.
Thanks Fatboy & Tommo! I am cautious about removing the head and, as you say, it easy to go down the road of trying to plan for every possible failure, even if they never happen. Charlie
othorton Member Since: 22 Jul 2019 Location: London Posts: 104 ![]() ![]() ![]() |
I'd do your clutch spigot bearing if the engine is out. TD5s are notorious for them whining and as a really cheap part it makes sense to replace.
Yes that’s on the list. Has been making a noise for a while.
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
