Home > Td5 > AS10
davidblythe
AS10
My ex utility 110 has no key fob and starts ok so presume there is no immobiliser
have a pathological dislike of immobilisers due mainly to Ducati ownership
who can code the AS10 on my 90 to remove the immobiliser part, will a nanocom do it ?
Post #815262 15th Feb 2020 3:27pm
markb110
Might pay to speak to your insurance company first.
With all the Defender thefts they might withdraw their cover , that in turns means when you look for new cover you would have to lie at the disclaimer section, ie ‘have you ever been refused cover’.
This in turn would cause you more problems down the line and not just with a theft claim. Insurance companies do talk to each other via the Motor Insurance Database.
I would not do it
Post #815288 15th Feb 2020 7:14pm
grafty99
There is no immobiliser activated on a basic spec Td5 10AS. It is, however, required for the ECU to run the engine. If you remove the 10AS, the ECU and 10AS won't do their "handshake" and the engine won't run.
You can have the engine ECU modified to not look for the 10AS unit but as long as you have no water ingress near the 10AS module (that is likely to make the 10AS wet) then they're pretty reliable and aren't prone to failure (other than PCB corrosion due to the aforementioned water problem).
There are plenty of 20+ year old Td5s out there running around with their original 10AS units (mine is 17 years old)
For me it would be a case of, if it ain't broke, don't fix it! Thumbs Up
P. S. In the current climate of high levels of theft - I would probably go the opposite way and have the alarm and immobiliser function activated in the 10AS and buy a couple of fobs. 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #815332 16th Feb 2020 7:04am
