Home > eBay & Bargain Spots > Aldi Car Battery Charger 12.99 |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
https://www.aldi.co.uk/auto-xs-car-battery...0347442700
Don't know how good it is as I use a CTEK |
11th Feb 2020 5:38pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1329 |
I've a couple of these and had them for a couple of years, do the job no problem. just not as flash as some others.
11th Feb 2020 5:40pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Do you mean series or Parallel? Putting a 12V battery in series would give you somewhere around 19-24V, which it probably also wouldn't charge!
11th Feb 2020 8:48pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I’ve got one of 5hose, it works great as a maintainer/topper upper, but takes an age if the battery is significantly discharged. 2007 110 TDCi Station Wagon XS
11th Feb 2020 9:00pm |
Paul1275s Member Since: 21 Apr 2019 Location: East Sussex Posts: 80 |
You are correct! 2003 Defender 110 TD5 SW 2003 Caterham 7 2006 Mini Cooper GP |
11th Feb 2020 9:05pm |
Also, if they are like the earlier version, and unlike a CTEK, if you have a power cut, even momentarily, they drop out and go into standby mode.
12th Feb 2020 4:59pm |
This one drops to motorcycle mode after a power cut, so it continues charging but at much reduced peak amps. 2007 110 TDCi Station Wagon XS
12th Feb 2020 5:50pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
supacat is right I have one and it drops out after power loss still handy though
14th Feb 2020 2:12pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Does anyone know if this will charge Lithium and/or AGM?
I have motorbikes with Lithium, and my CTEK won't charge them... Thanks in advance! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
15th Feb 2020 8:33am |
It has a cold weather profile with a higher charge voltage which manual says should also be used for AGM. It doesn’t have a setting for lithium. 2007 110 TDCi Station Wagon XS
15th Feb 2020 9:00am |
Lithium is usually in another price category altogether.
15th Feb 2020 10:31am |
OK. Thanks chaps.. Saved me a wasted drive to Aldi Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
15th Feb 2020 12:39pm |
