Home > In Car Electronics > Poll on if you've upgraded your head unit to a DAB receiver?
Have you upgraded the sound system in your defender to a fancy DAB radio.
No, I'm perfectly happy as it came thank you!
28%
 28%  [11]
Yes, I've upgraded and now have DAB reception.
71%
 71%  [27]
Total Votes: 38
PCM
I've had a few issues with my new fancy head unit. Firstly the model had a design flaw that took months to fix and then recently I've had a load of DAB radio interference from a dlr setup in a bumper.
When I rang the supplier of the bumper/drl's they said they'd sold hundreds to defenders and never had a problem. As the issue is relating to DAB radio they said most defender owners probably just use FM in the original radio.
Hence the question.
Feel free to add photos. New or old. Thumbs Up
For clarity I have a kenwood double din job (same as sold by Mudstuff)
Use the standard antenna and a DAB splitter and have a set of upgraded Audison speakers in the dash and under the seats with a Hertz amp in the battery box. Sounds simply awesome. (When driving below 50mph Rolling with laughter )
Post #812410 28th Jan 2020 11:47pm
grafty99
I have DAB in my 90 and JWSpeaker DRLs. No signal or interface problems here Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #812411 29th Jan 2020 12:02am
grafty99
I should add that I'm using a splitter on the standard LR aerial Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #812412 29th Jan 2020 12:03am
williamthedog
Kenwood dab in mine. Works well even with the stick on the screen aerial Thumbs Up
Post #812419 29th Jan 2020 5:17am
notxal
United Kingdom 2014 Defender 90 Puma 2.2 HT Aintree Green
Alpine DAB in mine with powered Panasonic sub woofer but with a separate DAB aerial. No issues
Post #812421 29th Jan 2020 6:14am
bankz5152
Cant answer the poll as I have DAB just rarely if ever works. Tried two windscreen ones, nope, powered 12v one earthed to the battery nope. Not treid a splitter but dont hold out hope.
Even a new Headunit, two actually!
Post #812422 29th Jan 2020 6:18am
hank
Alpine DAB receiver with a Connects2 CT27AA136 Splitter. Works well > 110 XS Double Cab
Post #812423 29th Jan 2020 6:23am
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
Splitter with standard aerial also. Thumbs Up Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #812427 29th Jan 2020 7:17am
Rashers
Could do with a third option - Still have the factory fitted radio, would like a DAB one, but am getting conflicting views Laughing
Off topic a little, but both charging my iPhone and my Tom Tom sat nav, if mounted too close to the factory fit Kenwood can give horrendous interference.
Post #812430 29th Jan 2020 8:26am
cold
JVC M745DBT here -
1) Originally with LR aerial and Nakatanenga splitter (the one supplied with aerial)
- Worked ok
Fitted new DRL’s - awful reception in places - added RF chokes improved
2) Replaced JVC unit with later model
- no benefit maybe worse
3) Disconnected DRLs and fitted Nakatanenga aerial
- Better , still felt could be improved
4) Changed Nakatanenga splitter
- Better still
5) RF chokes on all my lights
- Pretty good now - not as good as out other cars but close
Post #812433 29th Jan 2020 8:33am
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Pioneer flip out head unit in mine. Fitted with the Nakatanenga DAB aerial and spliiter which feeds both FM and DAB.
DRL's in the front bumper from uproar4x4 fitted at a later date, zero issues on either front.
Very happy with my setup Thumbs Up
Post #812438 29th Jan 2020 9:11am
Mo Murphy
I run everything off my phone so I have no need for DAB.
50 Shades of Pennine Grey
Post #812459 29th Jan 2020 10:51am
Morepower
New Zealand
CDE136BT... Looks like the factory install... only issue is the usb is on the back... So extended it to the glovebox
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #812542 29th Jan 2020 7:33pm
paulas
I have a pioneer flip up with focal speakers and a sub woofer. Sound is really good BUT the DAB cuts out when I switch on the LED headlights. Apparently some sort of interference. Headlamps are Thomas Performance.
Post #814349 9th Feb 2020 5:12pm
Banbury
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
No interference with:
-JVC KD-X561DBT DAB with DAB "patch" aerial + Focal Speakers (front and rear) and cubby box sub
- plus JWSpeaker dual-burn with DRL
Post #814356 9th Feb 2020 5:27pm
