![]() | Home > Puma (Tdci) > Engine temperature dropping significant at idle |
Blue Member Since: 13 Aug 2019 Location: UK Posts: 45 ![]() ![]() |
Could be your thermostat is stuck open, and the engine can't get up to usual operating temprature?
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Fairly typical for a puma....
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
How’s the coolant quantity ?
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I shouldn't worry the difference between low and high on the gauge represent about 3 degrees centigrade, The fan and radiator are doing what they are supposed to do. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
It is OK if the temperature drops a bit, but not to its lowest point. Check if the EGR cooler is not leaking. This happened to me some years ago and I was experiencing the same symptoms. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
