![]() | Home > Td5 > Td5 fuel guage... |
![]() Click image to enlarge ![]() Click image to enlarge with fuel gauge out of cct use meter check tank sender resistor E = 326 ohms 1/4 = 245 ohms 1/2 = 121 ohms 3/4 = 63 ohms F = 8 ohms you may have bad ground return from the sender ![]() Click image to enlarge ground path from sender C0287 ![]() C0550-9 ![]() Click image to enlarge The gauge grounds go thought C0278 and to C0550 ![]() Click image to enlarge Last edited by dorsetsmith on 6th Feb 2020 12:53pm. Edited 7 times in total |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Cheers DS.... I'll get metering.
I wondered if there was a dodgy earth somewhere; will get underneath with a torch as well and see if anything is amiss.. maybe run a temporary one to the instrument panel and see if there's any change. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
The sender is already earthed back at the instrument pack loom and not locally at the sender, see the A47 splice on the right of the bottom diagram in DS's post.
To take the speedo out of the circuit, disconnect the pink plug with the green/black and light green/wires and bridge those wires. You can still drive with that pink plug disconnected from the speedo as it's only the fuel gauge control wires on a Td5, on a ROW Tdi it also has the coolant gauge control on that plug. The power and speedo signal go via the other pink plug. ![]() ![]() |
Thanks Martin, I'll have a play later on
Finally had chance today to whip the dash off and short the two green/black wires.
Perfect, guage read instantly as it should. Although now bounces around like it's a series 2 fuel guage! haha Soooo.... aside from sending my speedo off to someone to get the transistor changed (or pulling it apart myself but I don't really want the bezel damaged), does anyone have any links for a small dampening circuit that I can put inline with (i assume) the green/blacks to stop the needle from bouncing around all over the place? |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1893 ![]() ![]() |
Watching this, as think I would also like sometthing like this.
Put the Td5 gauge in yesterday (into a 300tdi loom/Td5 tank) and it does just as you've described. Sits fine if the car is stationary or on a good flat road surface, but any movement or bends, and it's jumping about the place. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
After driving it for a week or 2 like this, ^^^^. It's not actually that bad.... certainly better (And more accurate) than the way it was before.
Unless I can come up withg a damper circuit, or another speedo, I'll just leave it as is. |
If the speedo isn't faulty (like diesel jim's) then the gauge should be wired via the speedo for the damping.
Thanks Martin.
I'm guessing that might not apply to the 300Tdi speedo?? Great if it did. Mine is a 300Tdi 1994, and while I've changed other stuff, including the tank, I have kept the original speedo exactly as per the 1994 wiring. (I did post another thread about trying to get the TD5 sender to work with the Tdi gauge, but the gist of that was that I would need the TD5 one. I got that, fitted it yesterday, and while it works and lights up, the needle isn't damped.) It hadn't occurred to me, coming from the Tdi electics, that there would be anything as complicated as a damper built into the speedo! This was my first test drive. I think I'll need to brim the tank, then see what happens over the coming days. If there's a solution I can work on fine, but I might end just accepting it like DieselJim. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Tdi gauge will work fine. I’ve run a Td5 sender with a pre-Td5 fuel gauge no problem.
Thanks Martin.
This is the other post ( https://www.defender2.net/forum/topic68833.html ) The new Tdi gauge just didn't seem to read correctly. Not showing a properly full tank; dropping off full faster than it used to; generally behaving differently and making me question its accuracy. I thought the Td5 one was the answer (and maybe it is) but on the road today it was jumping about the place, so I thought I'd see if I could find a further fix hence the posting here. I have to confess I haven't done the resistance test as recommended on the other thread. Figuring out positive to negative current flow, crimping on a few terminals, and working out a relay circuit is as techy as I get. Measuring resistance is juju I haven't tried yet - but every day's a school day and I guess I need to try that. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
