![]() | Home > In Car Electronics > Which single din head unit and antenna dab? |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
Several of us have gone for this one, which is good so far:
https://www.defender2.net/forum/topic68701.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8285 ![]() ![]() ![]() |
cheers, i see from the thread you have the one fitted. seems a good option.
Does it need the ISO wiring harness for fitting to a puma? https://www.mudstuff.co.uk/defender-iso-wiring-adapters.html i believe not on a 2010 one is that correct? Does it take a standard antenna was well as a DAB one? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2063 ![]() ![]() |
Hi James,
Use a dab/fm aerial splitter like this: https://www.dabonwheels.co.uk/product/aerial-converter-splitter/ And have al look at this: https://www.defender2.net/forum/topic54638.html?highlight=pioneer https://www.amazon.co.uk/Pioneer-1025922-A...B07PPV37FR I. have this unit in my Defender and am very pleased with it. ![]() Last edited by DAZ110 on 5th Feb 2020 11:21am. Edited 1 time in total |
Yes, the 'Puma pin' option.
Yes. I plan to use a Connect2 DAB splitter (bought from Amazon) to use the existing aerial for both. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thank you, will do some more research on the links you have sent. Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20872 ![]() ![]() |
Daz - Snap I have the same unit ready to go in. ![]() Just a matter of time due to other factors in my case. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 ![]() ![]() ![]() |
Thinking of upgrading my head unit soon too, I have an 07 puma and want to install the alpine UTE-200BT, Anyone know of the top of their heads if I need an ISO adapter and if so which one.
If the HU is DIN ISO which nearly all are it’ll plug straight in on your Defender.
The LR fit Alpine definitely isn't standard ISO, so it's worth checking the spec. of the one you're interested in. Darren
Wasn’t that one designed and fitted to 2012 onwards Defenders? As the 2012 on has its own wiring that isn’t ISO, I assume LR matched them up in the hope that people would accept its only that unit ‘Genuine Part’ that would fit. Where in fact you can get a loom to ISO adaptor to fit any aftermarket HU.
If I had a 2012 on myself personally I’d take off the factory plug / socket assembly and fit ISO. That way there isn’t any need for the bulk of adaptors. It’s annoying though and time consuming seeing as 07 - 2012 was ISO plug and play. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
2012 is LR fitting, did some digging today and 07 to 12 i believe is ISO, will pull mine and check soon. Cheers
What I was getting at is that the connector on the head unit itself may not be the standard ISO connectors - the typically brown and black 8 pin blocks, although sometimes moulded as one large connector. The connector into the back of the factory Alpine is completely different so the OP's intended unit may share that manufacturers' quirk.
You can get an idea of the difference from this pic that I took of the two different adaptors when changing my head unit recently. On the left hand ends are the vehicle loom plugs and on the right are the two different head unit connectors.: ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Yes, I know what you mean LRA.
In some cases some people end up with two adaptors. On mine which is ISO factory fitted to the vehicle: 1) So it's Factory ISO > ISO > HU Specific rear Connector into the back of the unit. 2) On the 2012 on it'd be LR loom Connector > ISO > ISO > HU Specific rear Connector. 3) I'd imagine the Alpine unit LR sell for the Defender is LR loom Connector > HU Specific rear Connector. The last option means there isn't the bulk of the additional ISO Connectors but then means your stuck with Alpine only (.if the HU rear one matches) and you don't have all options available of manufacturers that ISO suits as that's generic. It's blooming annoying that LR did that on the later models.. To suit all aftermarket options it'd be better to remove the factory spefic plug and replace with (1) male ISO (Keeps plugs and sockets to a minimum) OR use a factory Connector lead to male ISO adaptor instead (2). As you can tell, it just adds an annoying extra lead required at cost or hard wiring on the later models. The earlier models are simply plug and play. 3) Is an option but I bet that Alpine will have models that it would and wouldn't fit making it difficult to match up. I suppose you could always enquire though, so nothing ventured nothing gained. Should you change model though or manufacture down the line you'd then need ISO again though anyway. There is plenty of room behind there to fit the extra ISO Connector blocks in though so that isn't a big issue. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
A quick Google reveals that the Alpine UTE-200BT does indeed have the same type of rear connector as the LR fit model: ![]() Click image to enlarge If your Defender is of an age where it has standard ISO connectors behind the dash then you'll need an adapter like this, which can be found on eBay for not very much money: ![]() Click image to enlarge Search for 'Alpine 16 Pin ISO Wiring Harness'. Hope that helps. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
