![]() | Home > Puma (Tdci) > Help! I Need a Puma 2.2 under seat fuse box layout |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
sorry, dont have it with me but there should be a label under the lid.
If no one else has the layout, you could test them all; multimeter? One of the 60A is between battery and ignition switch. Then https://www.lrworkshop.com/diagrams/land-r...ca_2.2tdci |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 343 ![]() ![]() ![]() |
I think ignition fuse is FL1. Starter motor fuse is F3.
There's a fuse layout diagram in this thread https://www.defender2.net/forum/post299431.html Relay diagram here also https://www.defender2.net/forum/post385404.html Hope you get it sorted. |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Thank you JPE. It was ideed FL1. up and running again..
60 amp fuse link, what over loaded this 60 amp fuse
Hi
Couldn’t turn the key. Managed to get the ignition / lock off without cutting the clamp. I drilled a 4 mm hole and cut M5 treat in the security bolts (see picture). Screwed in a bolt and got the original bolts out. I was happy as hell. But when I took the cables off I got some sparks when it came to the steering column. This blew the 60A fuse. ![]() Click image to enlarge |
Ok
