Home > Technical > Seat belt repaired - Legal?
sconie
Hi all, I'm still finding niggles with my 2012 110 SW, the latest being a passenger noticed the front passenger seat belt hard in the middle of the strap, on inspection it seems to be a repair of sorts in the middle of the belt about 4cm long x 1cm wide. It looks like a heat weld or similar but feels rough to the touch. The 110 came with a brand new MOT and I'm surprised it would have passed as I thought any notable wear to a seat belt was a fail!
Question is, am I correct? if so will my AA dealer warranty cover replacement? if not is this an easy thing to source and replace myself?
Cheers.
Sconie
Post #813104 1st Feb 2020 6:30pm
Roy5695
Probably been trapped in the door close latch several times, frayed, and then some cowboy has melted it to make the damage less obvious than frayed material. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #813147 1st Feb 2020 9:14pm
Sulisuli
That needs to be changed for your own piece of mind Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #813157 1st Feb 2020 9:49pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Yep it is easy to replace yourself. You can get r a replacement from Exmor Trim or from Advanced Factors (forum sponsors).
Make sure to get the right belt for your vehicle.
Post #813168 1st Feb 2020 11:12pm
sconie
Thanks all, is there a serial number or part number I can identify on the belt so I can order the correct one?
Post #813169 1st Feb 2020 11:19pm
kmac
I got this one
https://www.exmoortrim.co.uk/front-4-door-reel-buckle.html . but call them and check if it will fit your vehicle
Genuine LR is about three times the price
Post #813315 2nd Feb 2020 11:32pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Tell me about it. I failed mot and got charged 3 times that price. Plus labour!!! 😭
Post #813327 3rd Feb 2020 7:40am
